Hello,everyone
Daylighting simulation of glass was performed with Radiance. In the three-phase method, I used WINDOW7.5 software to export a BSDF file in XML format. How do I use WINDOW software to export a BSDF file with higher accuracy that can be used in the five-phase method. Such as out put Tensor-tree BSDF files . Which settings are different between two methods ?
Thanks for your reply.
