I want to import .idf (ASHRAE building prototype) file in Open Studio (2.9.1). But it showing error:
"File is not valid to draft strictness. Check that IDF is of correct version and that all fields are valid against Energy+.idd.
The collection is INVALID at strictness level 'Draft', because of the errors: Field level data error of type Data Type Error is in an object of type 'Global Geometry Rules', name", in filed 0. Additional information about the error type: field level data is of an incorrect type."
Can you please help me to import idf file?
