Hi, I am à Ph D student and i simulating an evaporative cooling system in a building (ground floor + 2) by using directly Energy Plus. Each floor has an apartment and in each apartment there is an evaporative cooling system like EvaporativeCooler: Indirect: CelDekPad.
My question is how to create the IDF file or more precisely what should I put in the IDF files to run the simulation with the evaporative cooling system.
I have already done the simulation in HVAC configuration, but here I block on the input and output nodes of the system and the rest that goes with it.
just help me by advising me what to add or activate in my file.
thank you in advance
