How can I define an exterior ventilated wall?
Currently I'm defining the two objects "SurfacePropertyExteriorNaturalVentedCavity" and "SurfaceProperty:OtherSideConditionsModel" as reported in the attached file and then I'm selecting the correct Outside Boundary Conditions Object in "BuildingSurface:Detailed".
Do I need to define something else? Apparently in output the defined ventilated wall has not the correct importance, not modifying the total energy consumption of the building.
Thanks for the help.
