Radiant slab - Design capacity
Hi all,
I´m trying to model the effect of a radiant slab on the comfort conditions inside a space. I´m interested on seeing the impact of a radiant system with a Design capacity of 15 W/m2.
Is there any way to model it without doing all the HVAC loopings?
I´m not really familiar with HVAC modelling and was intending to find something similar to the ideal air loads method. I´ve tried with the ZoneHVAC:LowTemperatureRadiantVariableFlow object, but it requires all the HVAC connections.
I´m probably leaving a lot of factors on the side, but I had assumed it would be enough to define the Design capacity for it to be taken into account.
Thanks! Rafael
