Fix for non convex surface error?
I'm creating a multistory complex in order to run energy calculations in Energyplus, using SketchUp to create the geometry. I'm getting an error regarding non-convex surfaces and would like to know the quickest fix as I have many. If the reason for the error is for shadowing/daylighting, will leaving non convex surfaces that do not have windows change the results of the simulation? Will the model run if I were to leave these errors?
