Update geometry imported from IDF with FloorspaceJS
Hi,
I'm looking for a way to make OS believe that my geometry, that has been imported from an IDF file, has been created with FloorspaceJS so that the geometry update workflow is made easier.
Currently, I have to use the ImportEnvelopeAndInternalLoadsFromIdf measure or delete all my zones and import the new one from Geometry / Editor (this doesn't always work probably depending how the original geometry has been created/imported?).
Is there a way to do that? Maybe some kind of conversion tool?
Thank you, Adrien
Hi,
Thank you, Adrien
