Is it possible to use moisture measurements?
I have a model where I would like to add sources of humidity . I have measurements of humidity loads from plants, combustio, people... How would you advice to add these sources? In my case, adding moisture loads as a latent source does not seem to be so correct as I can only add moisture from people in the best case. I am interested in calculating RH levels as a result of different ventilation strategies.
