Active layer in wall
Hello Users,
is it possible to create an active layer inside a wall, like in TRNSYS? In TRNSYS you just specify some parameters like: - specific heat coefficient of water - pipe spacing (center to center) - pipe outside diameter - pipe wallthickness - pipe wall conductivity and thats it. regards, Arne
Hello Users,
Hello Users,
is Is it possible to create an active layer inside a wall, like in TRNSYS? In TRNSYS you just specify some parameters like: - like:
  • specific heat coefficient of water - water
  • pipe spacing (center to center) - center)
  • pipe outside diameter - diameter
  • pipe wallthickness - wallthickness
  • pipe wall conductivity conductivity
  • and thats it. regards, Arne
