Hello everyone
I want to ask a question about the example file: RoomAirflowNetwork.idf.
Can this RoomAirflowNetwork be calculated using the ideal load system? I modified this file and changed the original air-conditioning system: ZoneHVAC: PackagedTerminalAirConditioner to ZoneHVAC: IdealLoadsAirSystem.
But after the modification, the following error was displayed.
I have two questions: 1) Can't RoomAirflowNetwork be used in an IdealLoadsAirSystem? 2) How should I fix this problem? thank you for your help!
