Hi,
Could anyone help regarding the mismatch the number of vertices in adjacent surfaces after matching surfaces.So can you suggest I would fix this problem quickly through OSM edit file. For example
Surface 482, !- Name Floor, !- Surface Type , !- Construction Name {fedb58fb-85f6-42fb-9224-d914de3f2009}, !- Space Name Surface, !- Outside Boundary Condition {0a73280c-71e0-4c04-86b2-ae866a7dfca8}, !- Outside Boundary Condition Object NoSun, !- Sun Exposure NoWind, !- Wind Exposure , !- View Factor to Ground , !- Number of Vertices -1.95658023762474, 21.2500001941292, 0, !- X,Y,Z Vertex 1 {m}
-1.59287521774265, 20.489064658754, 0, !- X,Y,Z Vertex 2 {m}
-0.976562649273255, 19.0041590180099, 0, !- X,Y,Z Vertex 3 {m}
-0.524470438300814, 17.7300001941292, 0, !- X,Y,Z Vertex 4 {m}
-4.63326495613921, 17.7300001941292, 0, !- X,Y,Z Vertex 5 {m}
-4.63326495613921, 13.8900004067006, 0, !- X,Y,Z Vertex 6 {m}
-9.01326495613926, 13.8900004067006, 0, !- X,Y,Z Vertex 7 {m}
-9.01326495613926, 20.970062273176, 0, !- X,Y,Z Vertex 8 {m}
-5.33326495613917, 20.9700395084942, 0, !- X,Y,Z Vertex 9 {m}
-5.33326495613917, 21.2500001941292, 0; !- X,Y,Z Vertex 10 {m}
& other surface having 14 no. vertices.
OS:Surface, {0a73280c-71e0-4c04-86b2-ae866a7dfca8}, !- Handle Surface 946, !- Name RoofCeiling, !- Surface Type , !- Construction Name {dc962ea0-fced-43c7-b680-a227141c424c}, !- Space Name Surface, !- Outside Boundary Condition {568a12a8-3424-44b3-96ec-dfb4cf5a5898}, !- Outside Boundary Condition Object NoSun, !- Sun Exposure NoWind, !- Wind Exposure , !- View Factor to Ground , !- Number of Vertices -1.15505827125162e-014, -1.9799997874285, 2.025, !- X,Y,Z Vertex 1 {m}
0, 1.86000000000002, 2.025, !- X,Y,Z Vertex 2 {m}
4.10879451783821, 1.86000000000002, 2.025, !- X,Y,Z Vertex 3 {m}
3.65670230686596, 3.13415882388072, 2.025, !- X,Y,Z Vertex 4 {m}
3.04038973839656, 4.61906446462481, 2.025, !- X,Y,Z Vertex 5 {m}
2.67668471851429, 5.38000000000014, 2.025, !- X,Y,Z Vertex 6 {m}
-0.699999999999979, 5.3800000000001, 2.025, !- X,Y,Z Vertex 7 {m}
-0.699999999999979, 5.10003931436511, 2.025, !- X,Y,Z Vertex 8 {m}
-4.38000000000006, 5.10006207904691, 2.025, !- X,Y,Z Vertex 9 {m}
-4.38000000000004, 1.629999723366, 2.025, !- X,Y,Z Vertex 10 {m}
-1.95000000000017, 1.629999723366, 2.025, !- X,Y,Z Vertex 11 {m}
-1.95000000000017, -0.865000276633828, 2.025, !- X,Y,Z Vertex 12 {m}
-4.38000000000004, -0.865000276633828, 2.025, !- X,Y,Z Vertex 13 {m}
-4.38000000000006, -1.9799997874285, 2.025; !- X,Y,Z Vertex 14 {m}
