If you have multistory spaces, is there a simple way to merge spaces created from floor plans? For example, I have a two story space that spans the second and third floor of a building. When I create spaces from floor plans, I end up with the lower half of the space on the second floor and the upper half of the space on the third floor. What’s the easiest way to combine those spaces into a single two-story space?
