Hi,
Can someone suggest me how could I fix these following error in open-studio?
When I checked Sketch-up using tool (show errors & warning), there is no errors & warnings. When I wanted to run this model by applying baseline It has obtained with following errors.
ERROR The run failed with the following severe or fatal errors: CheckConvexity: Surface="SURFACE 357" is non-planar. Coincident Vertices will be removed as possible. ( 38.814, 24.420, 2.025) ( 38.814, 24.420, 0.000) ( 38.814, 24.420, 0.000)\nCheckConvexity: Surface="SURFACE 372" is non-planar. Coincident Vertices will be removed as possible. ( 21.394, 24.420, 2.025) ( 21.394, 24.420, 0.000) ( 21.394, 24.420, 0.000)\nCheckConvexity: Surface="SURFACE 402" is non-planar. Coincident Vertices will be removed as possible. ( 38.814, 24.420, 2.025) ( 38.814, 24.420, 0.000) ( 38.814, 24.420, 0.000)\nRoofCeiling:Detailed="SURFACE 946", Vertex size mismatch between base surface :SURFACE 946 and outside boundary surface: SURFACE 482 The vertex sizes are 14 for base surface and 10 for outside boundary surface. Please check inputs.\nRoofCeiling:Detailed="SURFACE 1054", Vertex size mismatch between base surface :SURFACE 1054 and outside boundary surface: SURFACE 6024 The vertex sizes are 26 for base surface and 27 for outside boundary surface.
