I tried to make a Horizontal Gshp system in Energyplus,and I couldn't find a template for this system in HVAC Templates,at the same time I was trying to use a heat pump(water to water )in the templates,and I would try to connect gshp system with that template of heat pump (with filling the the items related to gshp),but there are some errors related to nodes,and I couldn't find the nodes because I used the template, and it's not clear that which node it should be consider for gshp. I don't know It' s a correct method or it shouldn't be mix a templates with other parts.I will be appreciate if you know about this problem, and share your experience.
