I try to create a sensor in EMS for "Zone Thermal Comfort Fanger Model PPD", for further processing. From the RDD file, there is no sensor available called: "Zone Thermal Comfort Fanger Model PPD". However, there is a such variable in Output:Variable modules.
EnergyManagementSystem:Sensor,
ppd_sensor, !- Name
Core_ZN ZN, !- Output:Variable or Output:Meter Index Key Name
Zone Thermal Comfort Fanger Model PPD; !- Output:Variable or Output:Meter Name
Output:Variable,
Core_ZN ZN, !- Key Value
Zone Thermal Comfort Fanger Model PPD, !- Variable Name
timestep; !- Reporting Frequency
The Error i got:
* Severe * Invalid Output:Variable or Output:Meter Name =ZONE THERMAL COMFORT FANGER MODEL PPD * ~~~ * Entered in EnergyManagementSystem:Sensor=PPD_SENSOR * ~~~ * Output:Variable Name not found * Fatal * Errors found in processing Energy Management System input. Preceding condition causes termination.
(EnergyPlus 9.0).
How do i add such a variable to RDD? Thanks.
