noobie user - Energy plus is v9.0.1 and seems to runin standalone mode fine - as I have run the excercise files successfuly. installed openstudio v2.8 on Win7pro64 - the file builder and interface with Sketchup works ok and I have built a file with most of my desired input data complete, but when I hit run, the following output files are generated.
I don't see either openstudio or energy plus in my root drive path statement, but I don't know if they should be. I am running the files in the main Open Studio directory, which is installed on the C drive, as is the energy plus folder.
run.log details:
[17:07:32.930808 ERROR] :/ruby/2.2.0/gems/openstudio-workflow-1.3.3/lib/openstudio/workflow/util/energyplus.rb failed with Unable to find the EnergyPlus executable, :/ruby/2.2.0/gems/openstudio-workflow-1.3.3/lib/openstudio/workflow/util/energyplus.rb:18:in find_energyplus'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.3/lib/openstudio/workflow/util/energyplus.rb:94:incall_energyplus'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.3/lib/openstudio/workflow/jobs/run_energyplus.rb:44:in perform'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.3/lib/openstudio/workflow/run.rb:269:instep'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.3/lib/openstudio/workflow/run.rb:216:in run'
:/openstudio_cli.rb:937:inexecute'
:/openstudio_cli.rb:726:in execute'
:/openstudio_cli.rb:1703:in<main>'
eval:110:in eval'
eval:110:inrequire_embedded_absolute'
eval:95:in block in require'
eval:89:ineach'
eval:89:in require'
eval:2:in<main>'
[17:07:32.931808 ERROR] Found error in state 'simulation' with message ["undefined method each' for nil:NilClass::/ruby/2.2.0/gems/openstudio-workflow-1.3.3/lib/openstudio/workflow/util/energyplus.rb:30:inclean_directory'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.3/lib/openstudio/workflow/util/energyplus.rb:172:in ensure in call_energyplus'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.3/lib/openstudio/workflow/util/energyplus.rb:175:incall_energyplus'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.3/lib/openstudio/workflow/jobs/run_energyplus.rb:44:in perform'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.3/lib/openstudio/workflow/run.rb:269:instep'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.3/lib/openstudio/workflow/run.rb:216:in run'\n:/openstudio_cli.rb:937:inexecute'\n:/openstudio_cli.rb:726:in execute'\n:/openstudio_cli.rb:1703:in<main>'\neval:110:in eval'\neval:110:inrequire_embedded_absolute'\neval:95:in block in require'\neval:89:ineach'\neval:89:in require'\neval:2:in<main>'"]}
