Matching constructions when matching surfaces
Hello,
I've got an easy question but couldn't find the answer anywhere. I wonder what happens about the constructions when matching two different surfaces with the OpenStudio SketchUp plugin. If I have two matched surfaces, and want to define one construction for the wall defined by these two matched surfaces, do I need : 1 - To define the same construction that I want, for both surfaces ? 2 - To define the construction only for one surface, and define something like an air wall for the other ? 3 - Something else ?
Thank you for your help
Tanguy
