Has anyone else run into this error with Refrigerated Cases:
Severe ** GetRefrigerationInput: Refrigeration:Case="GLASS DOOR FROZEN FOOD A", invalid Defrost Energy Correction Curve Name not found:
The simulation then crashes.
I could not figure out any way to access or make changes to the field that contains the Defrost Energy Corrective Curve. Right now, it just says "None." Anytime I include a display case with antisweat heater capability this happens, which is kind of strange because defrost and anti-sweats are two different systems.
Thanks, Dan
