i want to simulate a naturally ventilated double-skin facade using energyplus. this model consists of a single zone building but introduces another uncontrolled zone for facade cavity. the outer glazing has upper and lower opening and naturally, the air will in through the lower opening, heated up in the cavity and passed out through upper opening. in that case, how can i measure this inlet, outlet and cavity air temperature?
