EMS routine doesn't work
Hi all! I am writing to you to understand why the EMS routine I have implemented in the model doesn’t give output values. I've created all the sensors, then the actuators. In the program section I've added the routine and in the global variable I've put variables coming from the routine. In Output:variable I've created a variable with the schedule of the routine, but after that analysis ends in the excel file in the column of the schedule result are 0.
Hi all! I am writing to you to understand why the EMS routine I have implemented in the model doesn’t give output values. I've created all the sensors, then the actuators. In the program section I've added the routine and in the global variable I've put variables coming from the routine. In Output:variable I've created a variable with the schedule of the routine, but after that analysis ends in the excel file in the column of the schedule result are 0.0. The EMS code is the following:
!- =========== ALL OBJECTS IN CLASS: ENERGYMANAGEMENTSYSTEM:PROGRAM ===========
EnergyManagementSystem:Program, Variable, !- Name set A1=-9.275, !- Program Line 1 set A2=-2.984, !- Program Line 2 set B1=0.233, !- A4 set B2=0.038, !- A5 set B3=-0.105, !- A6 set B4=-0.042, !- A7 set B5=0-057, !- A8 set B6=0.034, !- A9 set B7=-0.178, !- A10 set B8=-0.017, !- A11 set B9=0.062, !- A12 set B10=0.063, !- A13 set B11=0.032; !- A14
EnergyManagementSystem:Program, Window_Jones_2017, !- Name set Wind_Cur_State=Window1_S1_act, !- Program Line 1 if Wind_Cur_State == 0, !- Program Line 2 if OCC_KXS1>0, !- A4 set handle=A1+B1Tin_KXS1+B2RHin_KXS1-B3Tout-B4RHout+B5WS+B6Rain, !- A5 set handle=@Exp handle, !- A6 set handle=handle/(handle+1), !- A7 set R=@RandomUniform 0 1,!- A8 if handle>R, !- A9 set Window1_KXS1_act=1, !- A10 endif, !- A11 else, !- A12 set Window1_KXS1_act=0, !- A13 endif, !- A14 endif, !- A15 if Wind_Cur_State == 1, !- A16 if OCC_KXS1>0, !- A17 set handle=A2+B7Tin_KXS1+B8RHin_KXS1+B9Tout+B10WS+B11*Rain, !- A18 set handle=@Exp handle, !- A19 set handle=handle/(handle+1), !- A20 set R=@RandomUniform 0 1,!- A21 if handle>R, !- A22 set Window1_KXS1_act=0, !- A23 endif, !- A24 else, !- A25 set Window1_KXS1_act=0, !- A26 endif, !- A27 endif; !- A28
!- =========== ALL OBJECTS IN CLASS: OUTPUT:VARIABLE ===========
Output:Variable, SecondFloor:KXS1, !- Key Value Zone Mean Air Temperature, !- Variable Name Hourly; !- Reporting Frequency
Output:Variable, BLDG_KXS1_WINDOW1_Jones_2017_SCH, !- Key Value Schedule Value, !- Variable Name Hourly; !- Reporting Frequency
Output:Variable, SecondFloor:KXS1, !- Key Value Zone Air Relative Humidity, !- Variable Name Hourly; !- Reporting Frequency
Output:Variable, SecondFloor:KXS1, !- Key Value Zone People Occupant Count, !- Variable Name Hourly; !- Reporting Frequency
Output:Variable, Environment, !- Key Value Site Outdoor Air Drybulb Temperature, !- Variable Name Hourly; !- Reporting Frequency
Output:Variable, Environment, !- Key Value Site Outdoor Air Relative Humidity, !- Variable Name Hourly; !- Reporting Frequency
Output:Variable, Environment, !- Key Value Site Wind Speed, !- Variable Name Hourly; !- Reporting Frequency
Output:Variable, Environment, !- Key Value Site Rain Status, !- Variable Name Hourly; !- Reporting Frequency
Output:Variable, Occupancy KXS1_People, !- Key Value Schedule Value, !- Variable Name Hourly; !- Reporting Frequency
Output:Variable, PianoSecondo:KXS1, !- Key Value Zone Operative Temperature, !- Variable Name Hourly; !- Reporting Frequency
Hi all! I am writing to you to understand why the EMS routine I have implemented in the model doesn’t give output values. I've created all the sensors, then the actuators. In the program section I've added the routine and in the global variable I've put variables coming from the routine. In Output:variable I've created a variable with the schedule of the routine, but after that analysis ends in the excel file in the column of the schedule result are 0. The EMS code is the following:
=========== EnergyManagementSystem:Program, Variable, !- Name set A1=-9.275, !- Program Line 1 set A2=-2.984, !- Program Line 2 set B1=0.233, !- A4 set B2=0.038, !- A5 set B3=-0.105, !- A6 set B4=-0.042, !- A7 set B5=0-057, !- A8 set B6=0.034, !- A9 set B7=-0.178, !- A10 set B8=-0.017, !- A11 set B9=0.062, !- A12 set B10=0.063, !- A13 set B11=0.032; !- A14
A14 EnergyManagementSystem:Program, Window_Jones_2017, !- Name set Wind_Cur_State=Window1_S1_act, !- Program Line 1 if Wind_Cur_State == 0, !- Program Line 2 if OCC_KXS1>0, !- A4 set handle=A1+B1Tin_KXS1+B2RHin_KXS1-B3Tout-B4RHout+B5WS+B6Rain, handle=A1+B1*Tin_KXS1+B2*RHin_KXS1-B3*Tout-B4*RHout+B5*WS+B6*Rain, !- A5 set handle=@Exp handle, !- A6 set handle=handle/(handle+1), !- A7 set R=@RandomUniform 0 1,!- A8 if handle>R, !- A9 set Window1_KXS1_act=1, !- A10 endif, !- A11 else, !- A12 set Window1_KXS1_act=0, !- A13 endif, !- A14 endif, !- A15 if Wind_Cur_State == 1, !- A16 if OCC_KXS1>0, !- A17 set handle=A2+B7Tin_KXS1+B8RHin_KXS1+B9Tout+B10WS+B11*Rain, handle=A2+B7*Tin_KXS1+B8*RHin_KXS1+B9*Tout+B10*WS+B11*Rain, !- A18 set handle=@Exp handle, !- A19 set handle=handle/(handle+1), !- A20 set R=@RandomUniform 0 1,!- A21 if handle>R, !- A22 set Window1_KXS1_act=0, !- A23 endif, !- A24 else, !- A25 set Window1_KXS1_act=0, !- A26 endif, !- A27 endif; !- A28
A28 !- =========== ALL OBJECTS IN CLASS: OUTPUT:VARIABLE ===========
=========== Output:Variable, SecondFloor:KXS1, !- Key Value Zone Mean Air Temperature, !- Variable Name Hourly; !- Reporting Frequency
Frequency Output:Variable, BLDG_KXS1_WINDOW1_Jones_2017_SCH, !- Key Value Schedule Value, !- Variable Name Hourly; !- Reporting Frequency
Frequency Output:Variable, SecondFloor:KXS1, !- Key Value Zone Air Relative Humidity, !- Variable Name Hourly; !- Reporting Frequency
Frequency Output:Variable, SecondFloor:KXS1, !- Key Value Zone People Occupant Count, !- Variable Name Hourly; !- Reporting Frequency
Frequency Output:Variable, Environment, !- Key Value Site Outdoor Air Drybulb Temperature, !- Variable Name Hourly; !- Reporting Frequency
Frequency Output:Variable, Environment, !- Key Value Site Outdoor Air Relative Humidity, !- Variable Name Hourly; !- Reporting Frequency
Frequency Output:Variable, Environment, !- Key Value Site Wind Speed, !- Variable Name Hourly; !- Reporting Frequency
Frequency Output:Variable, Environment, !- Key Value Site Rain Status, !- Variable Name Hourly; !- Reporting Frequency
Frequency Output:Variable, Occupancy KXS1_People, !- Key Value Schedule Value, !- Variable Name Hourly; !- Reporting Frequency
Frequency Output:Variable, PianoSecondo:KXS1, !- Key Value Zone Operative Temperature, !- Variable Name Hourly; !- Reporting Frequency
Frequency
    Variable,                !- Name
    set B1=0.233,            !- A4
    set B2=0.038,            !- A5
    set B5=0-057,            !- A8
    set B6=0.034,            !- A9
     set handle=A1+B1*Tin_KXS1+B2*RHin_KXS1-B3*Tout-B4*RHout+B5*WS+B6*Rain,  !- A5
     if handle>R,             !- A9
     endif,                   !- A11
     else,                    !- A12
     endif,                   !- A14
    endif,                   !- A15
     set handle=A2+B7*Tin_KXS1+B8*RHin_KXS1+B9*Tout+B10*WS+B11*Rain,  !- A18
     if handle>R,             !- A22
     endif,                   !- A24
     else,                    !- A25
     endif,                   !- A27
    endif;                   !- A28
Output:Variable,
Output:Variable,
Output:Variable,
Output:Variable,
Output:Variable,
Output:Variable,
Output:Variable,
Output:Variable,
Output:Variable,
Output:Variable,
!-   ===========  ALL OBJECTS IN CLASS: ENERGYMANAGEMENTSYSTEM:SENSOR ===========
EnergyManagementSystem:Sensor,
   Tout,                    !- Name
   Environment,             !- Output:Variable or Output:Meter Index Key Name
   Site Outdoor Air Drybulb Temperature;  !- Output:Variable or Output:Meter Name
   RHout,                   !- Name
   Site Outdoor Air Relative Humidity;  !- Output:Variable or Output:Meter Name
   WS,                      !- Name
   Site Wind Speed;         !- Output:Variable or Output:Meter Name
   Rain,                    !- Name
   Site Rain Status;        !- Output:Variable or Output:Meter Name
   Tin_KXS1,                !- Name
   PianoSecondo:KXS1,       !- Output:Variable or Output:Meter Index Key Name
   Zone Mean Air Temperature;  !- Output:Variable or Output:Meter Name
   RHin_KXS1,               !- Name
   Zone Air Relative Humidity;  !- Output:Variable or Output:Meter Name
   OCC_KXS1,                !- Name
   Zone People Occupant Count;  !- Output:Variable or Output:Meter Name
   Tin_LM1,                 !- Name
   PianoSecondo:LM1,        !- Output:Variable or Output:Meter Index Key Name
    RHin_LM1,                !- Name
    OCC_LM1,                 !- Name
    Tin_LS1,                 !- Name
    PianoSecondo:LS1,        !- Output:Variable or Output:Meter Index Key Name
    RH_LS1,                  !- Name
    OCC_LS1,                 !- Name
!-   ===========  ALL OBJECTS IN CLASS: ENERGYMANAGEMENTSYSTEM:ACTUATOR ===========
    Window1_S1_act,          !- Name
    BLDG_KXS1_WINDOW1_Jones_2017_SCH,  !- Actuated Component Unique Name
    Schedule:Compact,        !- Actuated Component Type
    Schedule Value;          !- Actuated Component Control Type
    Window2_S1_act,          !- Name
    BLDG_KXS1_WINDOW2_Jones_2017_SCH,  !- Actuated Component Unique Name
    Window_LM1_act,          !- Name
    BLDG_LM1_WINDOW_Jones_2017_SCH,  !- Actuated Component Unique Name
    Window_LS1_act,          !- Name
    BLDG_LS1_WINDOW_Jones_2017_SCH,  !- Actuated Component Unique Name
    Variable,                !- Name
    set B1=0.233,            !- A4
    set B2=0.038,            !- A5
    set B5=0-057,            !- A8
    set B6=0.034,            !- A9
        if handle>R,             !- A9
        endif,                   !- A11
      else,                    !- A12
      endif,                   !- A14
    endif,                   !- A15
        if handle>R,             !- A22
        endif,                   !- A24
      else,                    !- A25
      endif,                   !- A27
    endif;                   !- A28
Output:Variable,
Output:Variable,
Output:Variable,
Output:Variable,
Output:Variable,
Output:Variable,
Output:Variable,
Output:Variable,
Output:Variable,
Output:Variable,
   Tout,                    !- Name
   RHout,                   !- Name
   WS,                      !- Name
   Rain,                    !- Name
   Tin_KXS1,                !- Name
   RHin_KXS1,               !- Name
   OCC_KXS1,                !- Name
   Tin_LM1,                 !- Name
    RHin_LM1,                !- Name
    OCC_LM1,                 !- Name
    Tin_LS1,                 !- Name
    RH_LS1,                  !- Name
    OCC_LS1,                 !- Name
    Variable,                !- Name
    set B1=0.233,            !- A4
    set B2=0.038,            !- A5
    set B5=0-057,            !- A8
    set B6=0.034,            !- A9
        if handle>R,             !- A9
        endif,                   !- A11
      else,                    !- A12
      endif,                   !- A14
    endif,                   !- A15
        if handle>R,             !- A22
        endif,                   !- A24
      else,                    !- A25
      endif,                   !- A27
    endif;                   !- A28
Output:Variable,
Output:Variable,
Output:Variable,
Output:Variable,
Output:Variable,
Output:Variable,
Output:Variable,
Output:Variable,
Output:Variable,
Output:Variable,
