I can simulate a double wall using the CTF (conduction transfer function) in Energyplus, but when I try to do it in HAMT model( heat and moisture transfer) I can't do the simulation, even after I define the "solid" HAMT properties. My question is: it is possible to simualte a double wall in Energyplus while using the model HAMT??? I can do a single wall simualtion. Thank you . Help me please, I'm doing a master's dissertation. Thank you. Email me to: Vanzelleres@gmail.com
