Hi Fellas! I run my simulation successfully but I found a warning error message that shows below:
* Warning * GetVRFInput: AirConditioner:VariableRefrigerantFlow="VRF OUTDOOR UNIT 1 VRF HEAT PUMP" curve values * ~~~ * ... Cooling Capacity Ratio Modifier Function of Low Temperature Curve Name = VRF OUTDOOR UNIT 1 VRFCOOLCAPFT output is not equal to 1.0 (+ or - 10%) at rated conditions. * ~~~ * ... Curve output at rated conditions = 1.136
This error always in my simulation but it not severe. The question is what the error explains? It significantly affected the HVAC sizing result? Your answer will help me, thank you!
