Hello,
I tried to use jEPlus nowadays and there's an example to change window size with EP-Macro.
I can see
if #[Top[] LE Bottom[]]
set1 NewTop #eval[Bottom[] + 0.10]
Is it okay there no number inside []????
I think it's weird.
| 1 | initial version |
Hello,
I can see
I think it's weird.
| 2 | No.2 Revision |
Hello,
I can see
##if #[Top[] LE Is it okay there no number inside []????[]?
I think it's weird.
| 3 | retagged |
I can see
##if #[Top[] LE Bottom[]]
##set1 NewTop #eval[Bottom[] + 0.10]
I think it's weird.
