Hello,
Can you explain how the idf_max_fields field in json is calculated? Obviously it plays a very important role, because when it's not set properly, the simulation fails.
I do try to make a converter idf->json myself ( don't ask me why :) ), but I can't manage to match the converted file with idf_max_fields value to be the same in my convert and energyplus one.
I do use energyplus with the -c option to convert the idf file. Here is a partial from 5ZoneAirCooledWithDOASAirLoop.epJSON example file. I converted it with the -c option.
My understanding is to count all the fields set in the object in order to calculate the value. I do not count idf_order, idf_max_fields, idf_max_extensible_fields . Here is the example:
"Coil:Cooling:DX:TwoStageWithHumidityControlMode": {
"DOAS Cooling Coil": {
"air_inlet_node_name": "DOAS Supply Fan Outlet",
"air_outlet_node_name": "DOAS Cooling Coil Outlet",
"dehumidification_mode_1_stage_1_2_coil_performance_name": "DOAS Dehumid Perf 1+2",
"dehumidification_mode_1_stage_1_2_coil_performance_object_type": "CoilPerformance:DX:Cooling",
"dehumidification_mode_1_stage_1_coil_performance_name": "DOAS Dehumid Perf 1",
"dehumidification_mode_1_stage_1_coil_performance_object_type": "CoilPerformance:DX:Cooling",
"idf_max_extensible_fields": 0,
"idf_max_fields": 19,
"idf_order": 302,
"minimum_outdoor_dry_bulb_temperature_for_compressor_operation": 0,
"normal_mode_stage_1_2_coil_performance_name": "DOAS Standard Perf 1+2",
"normal_mode_stage_1_2_coil_performance_object_type": "CoilPerformance:DX:Cooling",
"normal_mode_stage_1_coil_performance_name": "DOAS Standard Perf 1",
"normal_mode_stage_1_coil_performance_object_type": "CoilPerformance:DX:Cooling",
"number_of_capacity_stages": 2,
"number_of_enhanced_dehumidification_modes": 1
It says idf_max_fields = 19 My json:
"number_of_enhanced_dehumidification_modes": 1,
"idf_max_fields": 14,
"idf_order": 302
Idf max fields is 14, because I do count 14 fields set including the name. I do not count idf_order, idf_max_fields, idf_max_extensible_fields . Can you explain why the energyplus one (the file generated with -c option) has idf_max_fields set to 19?
This causes simulation errors. When I make my json with idf_max_fields set to 19, the simulation completes successfully. Otherwise with 14, it gives errors.
And here is the error log:
Program Version,EnergyPlus, Version 9.0.1-bb7ca4f0da, YMD=2019.10.09 17:13,
************* Beginning Zone Sizing Calculations
** Warning ** Weather file location will be used rather than entered (IDF) Location object.
** ~~~ ** ..Location object=CHICAGO_IL_USA TMY2-94846
** ~~~ ** ..Weather File Location=Tampa International Ap FL USA TMY3 WMO#=722110
** ~~~ ** ..due to location differences, Latitude difference=[13.81] degrees, Longitude difference=[5.22] degrees.
** ~~~ ** ..Time Zone difference=[1.0] hour(s), Elevation difference=[96.84] percent, [184.00] meters.
************* Beginning System Sizing Calculations
************* Beginning Plant Sizing Calculations
** Severe ** GetDXCoils: Coil:Cooling:DX:TwoStageWithHumidityControlMode="DOAS COOLING COIL", invalid
** ~~~ ** ...not enough remaining fields for specified Number of Operating Modes.
** ~~~ ** ...Need additional Coil Performance Object Type and Coil Performance Object Name fields.
** Fatal ** GetDXCoils: Errors found in getting Coil:Cooling:DX:TwoStageWithHumidityControlMode input. Preceding condition(s) causes termination.
...Summary of Errors that led to program termination:
..... Reference severe error count=1
..... Last severe error=GetDXCoils: Coil:Cooling:DX:TwoStageWithHumidityControlMode="DOAS COOLING COIL", invalid
************* Warning: Node connection errors not checked - most system input has not been read (see previous warning).
************* Fatal error -- final processing. Program exited before simulations began. See previous error messages.
************* EnergyPlus Warmup Error Summary. During Warmup: 0 Warning; 0 Severe Errors.
************* EnergyPlus Sizing Error Summary. During Sizing: 1 Warning; 0 Severe Errors.
************* EnergyPlus Terminated--Fatal Error Detected. 1 Warning; 1 Severe Errors; Elapsed Time=00hr 00min 0.74sec
Thank you!!!
