I'm doing a simulation with OpenStudio and EnergyPlus. After the simulation I used Design Builder Result Viewer to graph "Site Outdoor Air Drybulb Temperature" and in the graph seem to be some data missing because there is 3 days with a constant temperature of -2.3°C, 12.6°C and 6,8°C in the middle of the summer. However I opened the EPW file in Elements and everything looks fine in those days and in the minimum/max Dry Bulb Temperatures for each month. Note: I'm in southern hemisphere, so summer is from december to march.
