I want to change the DesignDay objects in a model through an OpenStudio measure. Changing it will allow me to change the design day in the PAT.
I found the action performed when you click the Import DDY button, it seems like there is some well-worked logic to importing it and I think that using this method would be the best approach. Is there any way in the current SDK to access it?
