EMS Heating and Cooling setpoint actuators control Air temperature instead of Operative temperature
Hi Everyone,
I'm working on a script for heating or cooling setpoint temperatures. I need it to be portable to other models, so i'm trying to make it work with loops. The problem is that, although the temperature control calculation option is set to Operative Temperature, the EMS controls the Air temperature.
The script i'm using is quite simple:
<ForAllOccupiedZones>
 <LoopZoneVariableName>_FORSCRIPT_ACST_Schedule,
   <LoopZoneIDFName>,
   Zone Temperature Control,
   Cooling Setpoint;
<LoopNextZone>
   <LoopZoneVariableName>_FORSCRIPT_AHST_Schedule,
   <LoopZoneIDFName>,
   Heating Setpoint;
<LoopNextZone>
ApplyAST,
BeginTimestepBeforePredictor,
ApplyAST;
ApplyAST,
Set <LoopZoneVariableName>_FORSCRIPT_ACST_Schedule = 26,
Set <LoopZoneVariableName>_FORSCRIPT_AHST_Schedule = 23;
<LoopNextZone>
This is a screenshot of the results, that show that Zone Air Temperature (instead of Operative Temperature) is 26°C. The Cooling setpoint is the blue line, but it's behind the zone air temperature and can not be seen. Does anyone know why is this happening?
Please find attached the IDF, in case you need it: https://drive.google.com/open?id=1K5RTcgSmabFcEN9OTCNoAxpo4IU5ef4Q
Thanks in advance.
