Hello Everybody! I am currently working on DesignBuilder and trying to obtain surface node temperature of the wall. I was able to switch this function on in Outputs tab (Outputs/Simulation Output Options/Miscellaneous Outputs -> Surface node temperature...). I know that when you use this option, it gives wall temperature for every 15 mm of the wall thickness. Problem is that I need a temperature for a specific layer which is only 5 mm thick and located between two nodes. Is there any option to decrease the node step from 15 mm to 5 mm? Thank you in advance!
