Hello , I am a student who has recently used open studio, I am creating a small project concerning several apartments powered by a radiant floor heating system. The difficulty that I have encountered is that of not being able to define the system as I would like, as I do not know where to find the '' Coil Heating Low Temperature Radiant Constant Flow '' and an air-water heat pump for powering the system from insert both into the HVAC system. I tried searching in the BCL library but I find only an example of a system already defined called AEDGOfficeHvacRadiantDoas. I would be grateful if someone could give me help thanks.
