the charts are empty in my beopt output
I asked about this previously and was told to check for an error report. It's here below. These first errors related to the clothes dryer don't make sense; Demand response option was False. changing it to DR and enabling the signal on site screen met the same result.
9/15/2019 10:27 PM: 1.xml: Error: A demand response option was selected (ClothesDryer), but the demand response signal was not enabled on the Site Screen. 9/15/2019 10:36 PM: 2.xml: Error: A demand response option was selected (ClothesDryer), but the demand response signal was not enabled on the Site Screen. 9/15/2019 10:36 PM: 3.xml: Error: A demand response option was selected (ClothesDryer), but the demand response signal was not enabled on the Site Screen. 9/15/2019 10:36 PM: 1.xml: Error: A demand response option was selected (ClothesDryer), but the demand response signal was not enabled on the Site Screen. 9/15/2019 10:49 PM: 3.xml: Traceback (most recent call last): 9/15/2019 10:49 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/15/2019 10:49 PM: 3.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/15/2019 10:49 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/15/2019 10:49 PM: 3.xml: sim.process(cost_file) 9/15/2019 10:49 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/15/2019 10:49 PM: 3.xml: self._processSystemSizing(geometry, unit, weather) 9/15/2019 10:49 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/15/2019 10:49 PM: 3.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/15/2019 10:49 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/15/2019 10:49 PM: 3.xml: self._process(sim, geometry, unit, weather) 9/15/2019 10:49 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/15/2019 10:49 PM: 3.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/15/2019 10:49 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/15/2019 10:49 PM: 3.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/15/2019 10:49 PM: 3.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/15/2019 10:49 PM: 2.xml: Traceback (most recent call last): 9/15/2019 10:49 PM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/15/2019 10:49 PM: 2.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/15/2019 10:49 PM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/15/2019 10:49 PM: 2.xml: sim.process(cost_file) 9/15/2019 10:49 PM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/15/2019 10:49 PM: 2.xml: self._processSystemSizing(geometry, unit, weather) 9/15/2019 10:49 PM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/15/2019 10:49 PM: 2.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/15/2019 10:49 PM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/15/2019 10:49 PM: 2.xml: self._process(sim, geometry, unit, weather) 9/15/2019 10:49 PM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/15/2019 10:49 PM: 2.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/15/2019 10:49 PM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/15/2019 10:49 PM: 2.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/15/2019 10:49 PM: 2.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/15/2019 10:49 PM: 4.xml: Error: A demand response option was selected (ClothesDryer), but the demand response signal was not enabled on the Site Screen. 9/15/2019 10:49 PM: 5.xml: Error: A demand response option was selected (ClothesDryer), but the demand response signal was not enabled on the Site Screen. 9/15/2019 10:49 PM: 1.xml: Traceback (most recent call last): 9/15/2019 10:49 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/15/2019 10:49 PM: 1.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/15/2019 10:49 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/15/2019 10:49 PM: 1.xml: sim.process(cost_file) 9/15/2019 10:49 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/15/2019 10:49 PM: 1.xml: self._processSystemSizing(geometry, unit, weather) 9/15/2019 10:49 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/15/2019 10:49 PM: 1.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/15/2019 10:49 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/15/2019 10:49 PM: 1.xml: self._process(sim, geometry, unit, weather) 9/15/2019 10:49 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/15/2019 10:49 PM: 1.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/15/2019 10:49 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/15/2019 10:49 PM: 1.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/15/2019 10:49 PM: 1.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/15/2019 10:49 PM: 6.xml: Error: A demand response option was selected (ClothesDryer), but the demand response signal was not enabled on the Site Screen. 9/17/2019 9:10 PM: 2.xml: Traceback (most recent call last): 9/17/2019 9:10 PM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/17/2019 9:10 PM: 2.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/17/2019 9:10 PM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/17/2019 9:10 PM: 2.xml: sim.process(cost_file) 9/17/2019 9:10 PM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/17/2019 9:10 PM: 2.xml: self._processSystemSizing(geometry, unit, weather) 9/17/2019 9:10 PM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/17/2019 9:10 PM: 2.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/17/2019 9:10 PM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/17/2019 9:10 PM: 2.xml: self._process(sim, geometry, unit, weather) 9/17/2019 9:10 PM: 3.xml: Traceback (most recent call last): 9/17/2019 9:10 PM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/17/2019 9:10 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/17/2019 9:10 PM: 2.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/17/2019 9:10 PM: 3.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/17/2019 9:10 PM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/17/2019 9:10 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/17/2019 9:10 PM: 2.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/17/2019 9:10 PM: 3.xml: sim.process(cost_file) 9/17/2019 9:10 PM: 2.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/17/2019 9:10 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/17/2019 9:10 PM: 3.xml: self._processSystemSizing(geometry, unit, weather) 9/17/2019 9:10 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/17/2019 9:10 PM: 3.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/17/2019 9:10 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/17/2019 9:10 PM: 3.xml: self._process(sim, geometry, unit, weather) 9/17/2019 9:10 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/17/2019 9:10 PM: 3.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/17/2019 9:10 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/17/2019 9:10 PM: 3.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/17/2019 9:10 PM: 3.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/17/2019 9:10 PM: 4.xml: Error: A demand response option was selected (ClothesDryer), but the demand response signal was not enabled on the Site Screen. 9/17/2019 9:10 PM: 1.xml: Traceback (most recent call last): 9/17/2019 9:10 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/17/2019 9:10 PM: 1.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/17/2019 9:10 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/17/2019 9:10 PM: 1.xml: sim.process(cost_file) 9/17/2019 9:10 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/17/2019 9:10 PM: 1.xml: self._processSystemSizing(geometry, unit, weather) 9/17/2019 9:10 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/17/2019 9:10 PM: 1.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/17/2019 9:10 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/17/2019 9:10 PM: 1.xml: self._process(sim, geometry, unit, weather) 9/17/2019 9:10 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/17/2019 9:10 PM: 1.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/17/2019 9:10 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/17/2019 9:10 PM: 1.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/17/2019 9:10 PM: 1.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/17/2019 9:10 PM: 5.xml: Error: A demand response option was selected (ClothesDryer), but the demand response signal was not enabled on the Site Screen. 9/17/2019 9:10 PM: 6.xml: Error: A demand response option was selected (ClothesDryer), but the demand response signal was not enabled on the Site Screen. 9/17/2019 9:51 PM: 2.xml: Traceback (most recent call last): 9/17/2019 9:51 PM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/17/2019 9:51 PM: 2.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/17/2019 9:51 PM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/17/2019 9:51 PM: 3.xml: Traceback (most recent call last): 9/17/2019 9:51 PM: 2.xml: sim.process(cost_file) 9/17/2019 9:51 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/17/2019 9:51 PM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/17/2019 9:51 PM: 3.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/17/2019 9:51 PM: 2.xml: self._processSystemSizing(geometry, unit, weather) 9/17/2019 9:51 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/17/2019 9:51 PM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/17/2019 9:51 PM: 3.xml: sim.process(cost_file) 9/17/2019 9:51 PM: 2.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/17/2019 9:51 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/17/2019 9:51 PM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/17/2019 9:51 PM: 3.xml: self._processSystemSizing(geometry, unit, weather) 9/17/2019 9:51 PM: 2.xml: self._process(sim, geometry, unit, weather) 9/17/2019 9:51 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/17/2019 9:51 PM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/17/2019 9:51 PM: 3.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/17/2019 9:51 PM: 2.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/17/2019 9:51 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/17/2019 9:51 PM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/17/2019 9:51 PM: 3.xml: self._process(sim, geometry, unit, weather) 9/17/2019 9:51 PM: 2.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/17/2019 9:51 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/17/2019 9:51 PM: 2.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/17/2019 9:51 PM: 3.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/17/2019 9:51 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/17/2019 9:51 PM: 3.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/17/2019 9:51 PM: 3.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/17/2019 9:51 PM: 4.xml: Error: A demand response option was selected (ClothesDryer), but the demand response signal was not enabled on the Site Screen. 9/17/2019 9:51 PM: 1.xml: Traceback (most recent call last): 9/17/2019 9:51 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/17/2019 9:51 PM: 1.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/17/2019 9:51 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/17/2019 9:51 PM: 1.xml: sim.process(cost_file) 9/17/2019 9:51 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/17/2019 9:51 PM: 1.xml: self._processSystemSizing(geometry, unit, weather) 9/17/2019 9:51 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/17/2019 9:51 PM: 1.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/17/2019 9:51 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/17/2019 9:51 PM: 1.xml: self._process(sim, geometry, unit, weather) 9/17/2019 9:51 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/17/2019 9:51 PM: 1.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/17/2019 9:51 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/17/2019 9:51 PM: 1.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/17/2019 9:51 PM: 1.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/17/2019 9:51 PM: 5.xml: Error: A demand response option was selected (ClothesDryer), but the demand response signal was not enabled on the Site Screen. 9/17/2019 9:51 PM: 6.xml: Error: A demand response option was selected (ClothesDryer), but the demand response signal was not enabled on the Site Screen. 9/20/2019 11:19 AM: 2.xml: Error: A demand response option was selected (ClothesDryer), but the demand response signal was not enabled on the Site Screen. 9/20/2019 11:20 AM: 1.xml: Traceback (most recent call last): 9/20/2019 11:20 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/20/2019 11:20 AM: 1.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/20/2019 11:20 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/20/2019 11:20 AM: 1.xml: sim.process(cost_file) 9/20/2019 11:20 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/20/2019 11:20 AM: 1.xml: self._processSystemSizing(geometry, unit, weather) 9/20/2019 11:20 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/20/2019 11:20 AM: 1.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/20/2019 11:20 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/20/2019 11:20 AM: 1.xml: self._process(sim, geometry, unit, weather) 9/20/2019 11:20 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/20/2019 11:20 AM: 1.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/20/2019 11:20 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/20/2019 11:20 AM: 1.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/20/2019 11:20 AM: 1.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/20/2019 11:30 AM: 2.xml: Error: A demand response option was selected (ClothesDryer), but the demand response signal was not enabled on the Site Screen. 9/20/2019 11:30 AM: 1.xml: Traceback (most recent call last): 9/20/2019 11:30 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/20/2019 11:30 AM: 1.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/20/2019 11:30 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/20/2019 11:30 AM: 1.xml: sim.process(cost_file) 9/20/2019 11:30 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/20/2019 11:30 AM: 1.xml: self._processSystemSizing(geometry, unit, weather) 9/20/2019 11:30 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/20/2019 11:30 AM: 1.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/20/2019 11:30 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/20/2019 11:30 AM: 1.xml: self._process(sim, geometry, unit, weather) 9/20/2019 11:30 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/20/2019 11:30 AM: 1.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/20/2019 11:30 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/20/2019 11:30 AM: 1.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/20/2019 11:30 AM: 1.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/20/2019 11:36 AM: 2.xml: Traceback (most recent call last): 9/20/2019 11:36 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/20/2019 11:36 AM: 2.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/20/2019 11:36 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/20/2019 11:36 AM: 2.xml: sim.process(cost_file) 9/20/2019 11:36 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/20/2019 11:36 AM: 2.xml: self._processSystemSizing(geometry, unit, weather) 9/20/2019 11:36 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/20/2019 11:36 AM: 2.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/20/2019 11:36 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/20/2019 11:36 AM: 2.xml: self._process(sim, geometry, unit, weather) 9/20/2019 11:36 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/20/2019 11:36 AM: 2.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/20/2019 11:36 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/20/2019 11:36 AM: 2.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/20/2019 11:36 AM: 2.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/20/2019 11:36 AM: 1.xml: Traceback (most recent call last): 9/20/2019 11:36 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/20/2019 11:36 AM: 1.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/20/2019 11:36 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/20/2019 11:36 AM: 1.xml: sim.process(cost_file) 9/20/2019 11:36 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/20/2019 11:36 AM: 1.xml: self._processSystemSizing(geometry, unit, weather) 9/20/2019 11:36 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/20/2019 11:36 AM: 1.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/20/2019 11:36 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/20/2019 11:36 AM: 1.xml: self._process(sim, geometry, unit, weather) 9/20/2019 11:36 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/20/2019 11:36 AM: 1.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/20/2019 11:36 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/20/2019 11:36 AM: 1.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/20/2019 11:36 AM: 1.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/20/2019 11:37 AM: 2.xml: Traceback (most recent call last): 9/20/2019 11:37 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/20/2019 11:37 AM: 2.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/20/2019 11:37 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/20/2019 11:37 AM: 2.xml: sim.process(cost_file) 9/20/2019 11:37 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/20/2019 11:37 AM: 2.xml: self._processSystemSizing(geometry, unit, weather) 9/20/2019 11:37 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/20/2019 11:37 AM: 2.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/20/2019 11:37 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/20/2019 11:37 AM: 2.xml: self._process(sim, geometry, unit, weather) 9/20/2019 11:37 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/20/2019 11:37 AM: 2.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/20/2019 11:37 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/20/2019 11:37 AM: 2.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/20/2019 11:37 AM: 2.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/20/2019 11:37 AM: 1.xml: Traceback (most recent call last): 9/20/2019 11:37 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/20/2019 11:37 AM: 1.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/20/2019 11:37 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/20/2019 11:37 AM: 1.xml: sim.process(cost_file) 9/20/2019 11:37 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/20/2019 11:37 AM: 1.xml: self._processSystemSizing(geometry, unit, weather) 9/20/2019 11:37 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/20/2019 11:37 AM: 1.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/20/2019 11:37 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/20/2019 11:37 AM: 1.xml: self._process(sim, geometry, unit, weather) 9/20/2019 11:37 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/20/2019 11:37 AM: 1.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/20/2019 11:37 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/20/2019 11:37 AM: 1.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/20/2019 11:37 AM: 1.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/20/2019 11:38 AM: 2.xml: Traceback (most recent call last): 9/20/2019 11:38 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/20/2019 11:38 AM: 2.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/20/2019 11:38 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/20/2019 11:38 AM: 2.xml: sim.process(cost_file) 9/20/2019 11:38 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/20/2019 11:38 AM: 2.xml: self._processSystemSizing(geometry, unit, weather) 9/20/2019 11:38 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/20/2019 11:38 AM: 2.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/20/2019 11:38 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/20/2019 11:38 AM: 2.xml: self._process(sim, geometry, unit, weather) 9/20/2019 11:38 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/20/2019 11:38 AM: 2.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/20/2019 11:38 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/20/2019 11:38 AM: 2.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/20/2019 11:38 AM: 2.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/20/2019 11:38 AM: 1.xml: Traceback (most recent call last): 9/20/2019 11:38 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/20/2019 11:38 AM: 1.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/20/2019 11:38 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/20/2019 11:38 AM: 1.xml: sim.process(cost_file) 9/20/2019 11:38 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/20/2019 11:38 AM: 1.xml: self._processSystemSizing(geometry, unit, weather) 9/20/2019 11:38 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/20/2019 11:38 AM: 1.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/20/2019 11:38 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/20/2019 11:38 AM: 1.xml: self._process(sim, geometry, unit, weather) 9/20/2019 11:38 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/20/2019 11:38 AM: 1.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/20/2019 11:38 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/20/2019 11:38 AM: 1.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/20/2019 11:38 AM: 1.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue'
I asked about this previously and was told to check for an error report. It's here below. These first errors Errors related to the clothes dryer don't make sense; Demand response option was False. changing is False, also standard is selected for appliance schedules. Changing it to DR and enabling the signal on site screen met the same result.similar errors.
9/15/2019 10:27 PM: 1.xml: 9/17/2019 9:10 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/17/2019 9:10 PM: 2.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/17/2019 9:10 PM: 3.xml: sim.process(cost_file) 9/17/2019 9:10 PM: 2.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/17/2019 9:10 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/17/2019 9:10 PM: 3.xml: self._processSystemSizing(geometry, unit, weather) 9/17/2019 9:10 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/17/2019 9:10 PM: 3.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/17/2019 9:10 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/17/2019 9:10 PM: 3.xml: self._process(sim, geometry, unit, weather) 9/17/2019 9:10 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/17/2019 9:10 PM: 3.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/17/2019 9:10 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/17/2019 9:10 PM: 3.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/17/2019 9:10 PM: 3.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/17/2019 9:10 PM: 4.xml: Error: A demand response option was selected (ClothesDryer), but the demand response signal was not enabled on the Site Screen. 9/15/2019 10:36 PM: 2.xml: 9/17/2019 9:10 PM: 1.xml: Traceback (most recent call last): 9/17/2019 9:10 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/17/2019 9:10 PM: 1.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/17/2019 9:10 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/17/2019 9:10 PM: 1.xml: sim.process(cost_file) 9/17/2019 9:10 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/17/2019 9:10 PM: 1.xml: self._processSystemSizing(geometry, unit, weather) 9/17/2019 9:10 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/17/2019 9:10 PM: 1.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/17/2019 9:10 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/17/2019 9:10 PM: 1.xml: self._process(sim, geometry, unit, weather) 9/17/2019 9:10 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/17/2019 9:10 PM: 1.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/17/2019 9:10 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/17/2019 9:10 PM: 1.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/17/2019 9:10 PM: 1.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/17/2019 9:10 PM: 5.xml: Error: A demand response option was selected (ClothesDryer), but the demand response signal was not enabled on the Site Screen. 9/15/2019 10:36 PM: 3.xml: 9/17/2019 9:10 PM: 6.xml: Error: A demand response option was selected (ClothesDryer), but the demand response signal was not enabled on the Site Screen. 9/15/2019 10:36 PM: 1.xml: 9/17/2019 9:51 PM: 2.xml: Traceback (most recent call last): 9/17/2019 9:51 PM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/17/2019 9:51 PM: 2.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/17/2019 9:51 PM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/17/2019 9:51 PM: 3.xml: Traceback (most recent call last): 9/17/2019 9:51 PM: 2.xml: sim.process(cost_file) 9/17/2019 9:51 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/17/2019 9:51 PM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/17/2019 9:51 PM: 3.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/17/2019 9:51 PM: 2.xml: self._processSystemSizing(geometry, unit, weather) 9/17/2019 9:51 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/17/2019 9:51 PM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/17/2019 9:51 PM: 3.xml: sim.process(cost_file) 9/17/2019 9:51 PM: 2.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/17/2019 9:51 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/17/2019 9:51 PM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/17/2019 9:51 PM: 3.xml: self._processSystemSizing(geometry, unit, weather) 9/17/2019 9:51 PM: 2.xml: self._process(sim, geometry, unit, weather) 9/17/2019 9:51 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/17/2019 9:51 PM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/17/2019 9:51 PM: 3.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/17/2019 9:51 PM: 2.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/17/2019 9:51 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/17/2019 9:51 PM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/17/2019 9:51 PM: 3.xml: self._process(sim, geometry, unit, weather) 9/17/2019 9:51 PM: 2.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/17/2019 9:51 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/17/2019 9:51 PM: 2.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/17/2019 9:51 PM: 3.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/17/2019 9:51 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/17/2019 9:51 PM: 3.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/17/2019 9:51 PM: 3.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/17/2019 9:51 PM: 4.xml: Error: A demand response option was selected (ClothesDryer), but the demand response signal was not enabled on the Site Screen. 9/15/2019 10:49 PM: 3.xml: 9/17/2019 9:51 PM: 1.xml: Traceback (most recent call last): 9/15/2019 10:49 PM: 3.xml: 9/17/2019 9:51 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/15/2019 10:49 PM: 3.xml: 9/17/2019 9:51 PM: 1.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/15/2019 10:49 PM: 3.xml: 9/17/2019 9:51 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/15/2019 10:49 PM: 3.xml: 9/17/2019 9:51 PM: 1.xml: sim.process(cost_file) 9/15/2019 10:49 PM: 3.xml: 9/17/2019 9:51 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/15/2019 10:49 PM: 3.xml: 9/17/2019 9:51 PM: 1.xml: self._processSystemSizing(geometry, unit, weather) 9/15/2019 10:49 PM: 3.xml: 9/17/2019 9:51 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/15/2019 10:49 PM: 3.xml: 9/17/2019 9:51 PM: 1.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/15/2019 10:49 PM: 3.xml: 9/17/2019 9:51 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/15/2019 10:49 PM: 3.xml: 9/17/2019 9:51 PM: 1.xml: self._process(sim, geometry, unit, weather) 9/15/2019 10:49 PM: 3.xml: 9/17/2019 9:51 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/15/2019 10:49 PM: 3.xml: 9/17/2019 9:51 PM: 1.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/15/2019 10:49 PM: 3.xml: 9/17/2019 9:51 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/15/2019 10:49 PM: 3.xml: 9/17/2019 9:51 PM: 1.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/15/2019 10:49 PM: 3.xml: 9/17/2019 9:51 PM: 1.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/15/2019 10:49 PM: 2.xml: Traceback (most recent call last): 9/15/2019 10:49 PM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/15/2019 10:49 PM: 2.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/15/2019 10:49 PM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/15/2019 10:49 PM: 2.xml: sim.process(cost_file) 9/15/2019 10:49 PM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/15/2019 10:49 PM: 2.xml: self._processSystemSizing(geometry, unit, weather) 9/15/2019 10:49 PM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/15/2019 10:49 PM: 2.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/15/2019 10:49 PM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/15/2019 10:49 PM: 2.xml: self._process(sim, geometry, unit, weather) 9/15/2019 10:49 PM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/15/2019 10:49 PM: 2.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/15/2019 10:49 PM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/15/2019 10:49 PM: 2.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/15/2019 10:49 PM: 2.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/15/2019 10:49 PM: 4.xml: 9/17/2019 9:51 PM: 5.xml: Error: A demand response option was selected (ClothesDryer), but the demand response signal was not enabled on the Site Screen. 9/15/2019 10:49 PM: 5.xml: 9/17/2019 9:51 PM: 6.xml: Error: A demand response option was selected (ClothesDryer), but the demand response signal was not enabled on the Site Screen. 9/15/2019 10:49 PM: 1.xml: Traceback (most recent call last): 9/15/2019 10:49 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/15/2019 10:49 PM: 1.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/15/2019 10:49 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/15/2019 10:49 PM: 1.xml: sim.process(cost_file) 9/15/2019 10:49 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/15/2019 10:49 PM: 1.xml: self._processSystemSizing(geometry, unit, weather) 9/15/2019 10:49 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/15/2019 10:49 PM: 1.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/15/2019 10:49 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/15/2019 10:49 PM: 1.xml: self._process(sim, geometry, unit, weather) 9/15/2019 10:49 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/15/2019 10:49 PM: 1.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/15/2019 10:49 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/15/2019 10:49 PM: 1.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/15/2019 10:49 PM: 1.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/15/2019 10:49 PM: 6.xml: 9/20/2019 11:19 AM: 2.xml: Error: A demand response option was selected (ClothesDryer), but the demand response signal was not enabled on the Site Screen. 9/17/2019 9:10 PM: 2.xml: 9/20/2019 11:20 AM: 1.xml: Traceback (most recent call last): 9/17/2019 9:10 PM: 2.xml: 9/20/2019 11:20 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/17/2019 9:10 PM: 2.xml: 9/20/2019 11:20 AM: 1.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/17/2019 9:10 PM: 2.xml: 9/20/2019 11:20 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/17/2019 9:10 PM: 2.xml: 9/20/2019 11:20 AM: 1.xml: sim.process(cost_file) 9/17/2019 9:10 PM: 2.xml: 9/20/2019 11:20 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/17/2019 9:10 PM: 2.xml: 9/20/2019 11:20 AM: 1.xml: self._processSystemSizing(geometry, unit, weather) 9/17/2019 9:10 PM: 2.xml: 9/20/2019 11:20 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/17/2019 9:10 PM: 2.xml: 9/20/2019 11:20 AM: 1.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/17/2019 9:10 PM: 2.xml: 9/20/2019 11:20 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/17/2019 9:10 PM: 2.xml: 9/20/2019 11:20 AM: 1.xml: self._process(sim, geometry, unit, weather) 9/17/2019 9:10 PM: 3.xml: Traceback (most recent call last): 9/17/2019 9:10 PM: 2.xml: 9/20/2019 11:20 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/17/2019 9:10 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/17/2019 9:10 PM: 2.xml: 9/20/2019 11:20 AM: 1.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/17/2019 9:10 PM: 3.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/17/2019 9:10 PM: 2.xml: 9/20/2019 11:20 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/17/2019 9:10 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/17/2019 9:10 PM: 2.xml: 9/20/2019 11:20 AM: 1.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/17/2019 9:10 PM: 3.xml: sim.process(cost_file) 9/17/2019 9:10 PM: 2.xml: 9/20/2019 11:20 AM: 1.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/17/2019 9:10 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/17/2019 9:10 PM: 3.xml: self._processSystemSizing(geometry, unit, weather) 9/17/2019 9:10 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/17/2019 9:10 PM: 3.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/17/2019 9:10 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/17/2019 9:10 PM: 3.xml: self._process(sim, geometry, unit, weather) 9/17/2019 9:10 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/17/2019 9:10 PM: 3.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/17/2019 9:10 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/17/2019 9:10 PM: 3.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/17/2019 9:10 PM: 3.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/17/2019 9:10 PM: 4.xml: 9/20/2019 11:30 AM: 2.xml: Error: A demand response option was selected (ClothesDryer), but the demand response signal was not enabled on the Site Screen. 9/17/2019 9:10 PM: 9/20/2019 11:30 AM: 1.xml: Traceback (most recent call last): 9/17/2019 9:10 PM: 9/20/2019 11:30 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/17/2019 9:10 PM: 9/20/2019 11:30 AM: 1.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/17/2019 9:10 PM: 9/20/2019 11:30 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/17/2019 9:10 PM: 9/20/2019 11:30 AM: 1.xml: sim.process(cost_file) 9/17/2019 9:10 PM: 9/20/2019 11:30 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/17/2019 9:10 PM: 9/20/2019 11:30 AM: 1.xml: self._processSystemSizing(geometry, unit, weather) 9/17/2019 9:10 PM: 9/20/2019 11:30 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/17/2019 9:10 PM: 9/20/2019 11:30 AM: 1.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/17/2019 9:10 PM: 9/20/2019 11:30 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/17/2019 9:10 PM: 9/20/2019 11:30 AM: 1.xml: self._process(sim, geometry, unit, weather) 9/17/2019 9:10 PM: 9/20/2019 11:30 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/17/2019 9:10 PM: 9/20/2019 11:30 AM: 1.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/17/2019 9:10 PM: 9/20/2019 11:30 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/17/2019 9:10 PM: 9/20/2019 11:30 AM: 1.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/17/2019 9:10 PM: 9/20/2019 11:30 AM: 1.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/17/2019 9:10 PM: 5.xml: Error: A demand response option was selected (ClothesDryer), but the demand response signal was not enabled on the Site Screen. 9/17/2019 9:10 PM: 6.xml: Error: A demand response option was selected (ClothesDryer), but the demand response signal was not enabled on the Site Screen. 9/17/2019 9:51 PM: 9/20/2019 11:36 AM: 2.xml: Traceback (most recent call last): 9/17/2019 9:51 PM: 9/20/2019 11:36 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/17/2019 9:51 PM: 9/20/2019 11:36 AM: 2.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/17/2019 9:51 PM: 9/20/2019 11:36 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/17/2019 9:51 PM: 3.xml: Traceback (most recent call last): 9/17/2019 9:51 PM: 9/20/2019 11:36 AM: 2.xml: sim.process(cost_file) 9/17/2019 9:51 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/17/2019 9:51 PM: 9/20/2019 11:36 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/17/2019 9:51 PM: 3.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/17/2019 9:51 PM: 9/20/2019 11:36 AM: 2.xml: self._processSystemSizing(geometry, unit, weather) 9/17/2019 9:51 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/17/2019 9:51 PM: 9/20/2019 11:36 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/17/2019 9:51 PM: 3.xml: sim.process(cost_file) 9/17/2019 9:51 PM: 9/20/2019 11:36 AM: 2.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/17/2019 9:51 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/17/2019 9:51 PM: 9/20/2019 11:36 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/17/2019 9:51 PM: 3.xml: self._processSystemSizing(geometry, unit, weather) 9/17/2019 9:51 PM: 9/20/2019 11:36 AM: 2.xml: self._process(sim, geometry, unit, weather) 9/17/2019 9:51 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/17/2019 9:51 PM: 9/20/2019 11:36 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/17/2019 9:51 PM: 3.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/17/2019 9:51 PM: 9/20/2019 11:36 AM: 2.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/17/2019 9:51 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/17/2019 9:51 PM: 9/20/2019 11:36 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/17/2019 9:51 PM: 3.xml: self._process(sim, geometry, unit, weather) 9/17/2019 9:51 PM: 9/20/2019 11:36 AM: 2.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/17/2019 9:51 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/17/2019 9:51 PM: 9/20/2019 11:36 AM: 2.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/17/2019 9:51 PM: 3.xml: 9/20/2019 11:36 AM: 1.xml: Traceback (most recent call last): 9/20/2019 11:36 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/20/2019 11:36 AM: 1.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/20/2019 11:36 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/20/2019 11:36 AM: 1.xml: sim.process(cost_file) 9/20/2019 11:36 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/20/2019 11:36 AM: 1.xml: self._processSystemSizing(geometry, unit, weather) 9/20/2019 11:36 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/20/2019 11:36 AM: 1.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/20/2019 11:36 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/20/2019 11:36 AM: 1.xml: self._process(sim, geometry, unit, weather) 9/20/2019 11:36 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/20/2019 11:36 AM: 1.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/17/2019 9:51 PM: 3.xml: 9/20/2019 11:36 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/17/2019 9:51 PM: 3.xml: 9/20/2019 11:36 AM: 1.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/17/2019 9:51 PM: 3.xml: 9/20/2019 11:36 AM: 1.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/17/2019 9:51 PM: 4.xml: Error: A demand response option was selected (ClothesDryer), but the demand response signal was not enabled on the Site Screen. 9/17/2019 9:51 PM: 1.xml: 9/20/2019 11:37 AM: 2.xml: Traceback (most recent call last): 9/17/2019 9:51 PM: 1.xml: 9/20/2019 11:37 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/17/2019 9:51 PM: 1.xml: 9/20/2019 11:37 AM: 2.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/17/2019 9:51 PM: 1.xml: 9/20/2019 11:37 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/17/2019 9:51 PM: 1.xml: 9/20/2019 11:37 AM: 2.xml: sim.process(cost_file) 9/17/2019 9:51 PM: 1.xml: 9/20/2019 11:37 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/17/2019 9:51 PM: 1.xml: 9/20/2019 11:37 AM: 2.xml: self._processSystemSizing(geometry, unit, weather) 9/17/2019 9:51 PM: 1.xml: 9/20/2019 11:37 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/17/2019 9:51 PM: 1.xml: 9/20/2019 11:37 AM: 2.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/17/2019 9:51 PM: 1.xml: 9/20/2019 11:37 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/17/2019 9:51 PM: 1.xml: 9/20/2019 11:37 AM: 2.xml: self._process(sim, geometry, unit, weather) 9/17/2019 9:51 PM: 1.xml: 9/20/2019 11:37 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/17/2019 9:51 PM: 1.xml: 9/20/2019 11:37 AM: 2.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/17/2019 9:51 PM: 1.xml: 9/20/2019 11:37 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/17/2019 9:51 PM: 1.xml: 9/20/2019 11:37 AM: 2.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/17/2019 9:51 PM: 1.xml: 9/20/2019 11:37 AM: 2.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/17/2019 9:51 PM: 5.xml: Error: A demand response option was selected (ClothesDryer), but the demand response signal was not enabled on the Site Screen. 9/17/2019 9:51 PM: 6.xml: Error: A demand response option was selected (ClothesDryer), but the demand response signal was not enabled on the Site Screen. 9/20/2019 11:19 AM: 2.xml: Error: A demand response option was selected (ClothesDryer), but the demand response signal was not enabled on the Site Screen. 9/20/2019 11:20 9/20/2019 11:37 AM: 1.xml: Traceback (most recent call last): 9/20/2019 11:20 11:37 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/20/2019 11:20 11:37 AM: 1.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/20/2019 11:20 11:37 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/20/2019 11:20 11:37 AM: 1.xml: sim.process(cost_file) 9/20/2019 11:20 11:37 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/20/2019 11:20 11:37 AM: 1.xml: self._processSystemSizing(geometry, unit, weather) 9/20/2019 11:20 11:37 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/20/2019 11:20 11:37 AM: 1.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/20/2019 11:20 11:37 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/20/2019 11:20 11:37 AM: 1.xml: self._process(sim, geometry, unit, weather) 9/20/2019 11:20 11:37 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/20/2019 11:20 11:37 AM: 1.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/20/2019 11:20 11:37 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/20/2019 11:20 11:37 AM: 1.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/20/2019 11:20 11:37 AM: 1.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/20/2019 11:30 AM: 2.xml: Error: A demand response option was selected (ClothesDryer), but the demand response signal was not enabled on the Site Screen. 9/20/2019 11:30 AM: 1.xml: 11:38 AM: 2.xml: Traceback (most recent call last): 9/20/2019 11:30 AM: 1.xml: 11:38 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/20/2019 11:30 AM: 1.xml: 11:38 AM: 2.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/20/2019 11:30 AM: 1.xml: 11:38 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/20/2019 11:30 AM: 1.xml: 11:38 AM: 2.xml: sim.process(cost_file) 9/20/2019 11:30 AM: 1.xml: 11:38 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/20/2019 11:30 AM: 1.xml: 11:38 AM: 2.xml: self._processSystemSizing(geometry, unit, weather) 9/20/2019 11:30 AM: 1.xml: 11:38 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/20/2019 11:30 AM: 1.xml: 11:38 AM: 2.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/20/2019 11:30 AM: 1.xml: 11:38 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/20/2019 11:30 AM: 1.xml: 11:38 AM: 2.xml: self._process(sim, geometry, unit, weather) 9/20/2019 11:30 AM: 1.xml: 11:38 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/20/2019 11:30 AM: 1.xml: 11:38 AM: 2.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/20/2019 11:30 AM: 1.xml: 11:38 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/20/2019 11:30 AM: 1.xml: 11:38 AM: 2.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/20/2019 11:30 AM: 1.xml: 11:38 AM: 2.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/20/2019 11:36 AM: 2.xml: 11:38 AM: 1.xml: Traceback (most recent call last): 9/20/2019 11:36 AM: 2.xml: 11:38 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/20/2019 11:36 AM: 2.xml: 11:38 AM: 1.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/20/2019 11:36 AM: 2.xml: 11:38 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/20/2019 11:36 AM: 2.xml: 11:38 AM: 1.xml: sim.process(cost_file) 9/20/2019 11:36 AM: 2.xml: 11:38 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/20/2019 11:36 AM: 2.xml: 11:38 AM: 1.xml: self._processSystemSizing(geometry, unit, weather) 9/20/2019 11:36 AM: 2.xml: 11:38 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/20/2019 11:36 AM: 2.xml: 11:38 AM: 1.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/20/2019 11:36 AM: 2.xml: 11:38 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/20/2019 11:36 AM: 2.xml: 11:38 AM: 1.xml: self._process(sim, geometry, unit, weather) 9/20/2019 11:36 AM: 2.xml: 11:38 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/20/2019 11:36 AM: 2.xml: 11:38 AM: 1.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/20/2019 11:36 AM: 2.xml: 11:38 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/20/2019 11:36 AM: 2.xml: 11:38 AM: 1.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/20/2019 11:36 AM: 2.xml: 11:38 AM: 1.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/20/2019 11:36 AM: 1.xml: 11:54 AM: 2.xml: Traceback (most recent call last): 9/20/2019 11:36 AM: 1.xml: 11:54 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/20/2019 11:36 AM: 1.xml: 11:54 AM: 2.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/20/2019 11:36 AM: 1.xml: 11:54 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/20/2019 11:36 AM: 1.xml: 11:54 AM: 2.xml: sim.process(cost_file) 9/20/2019 11:36 AM: 1.xml: 11:54 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/20/2019 11:36 AM: 1.xml: 11:54 AM: 2.xml: self._processSystemSizing(geometry, unit, weather) 9/20/2019 11:36 AM: 1.xml: 11:54 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/20/2019 11:36 AM: 1.xml: 11:54 AM: 2.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/20/2019 11:36 AM: 1.xml: 11:54 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/20/2019 11:36 AM: 1.xml: 11:54 AM: 2.xml: self._process(sim, geometry, unit, weather) 9/20/2019 11:36 AM: 1.xml: 11:54 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/20/2019 11:36 AM: 1.xml: 11:54 AM: 2.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/20/2019 11:36 AM: 1.xml: 11:54 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/20/2019 11:36 AM: 1.xml: 11:54 AM: 2.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/20/2019 11:36 AM: 1.xml: 11:54 AM: 2.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/20/2019 11:37 AM: 2.xml: 11:54 AM: 1.xml: Traceback (most recent call last): 9/20/2019 11:37 AM: 2.xml: 11:54 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/20/2019 11:37 AM: 2.xml: 11:54 AM: 1.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/20/2019 11:37 AM: 2.xml: 11:54 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/20/2019 11:37 AM: 2.xml: 11:54 AM: 1.xml: sim.process(cost_file) 9/20/2019 11:37 AM: 2.xml: 11:54 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/20/2019 11:37 AM: 2.xml: 11:54 AM: 1.xml: self._processSystemSizing(geometry, unit, weather) 9/20/2019 11:37 AM: 2.xml: 11:54 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/20/2019 11:37 AM: 2.xml: 11:54 AM: 1.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/20/2019 11:37 AM: 2.xml: 11:54 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/20/2019 11:37 AM: 2.xml: 11:54 AM: 1.xml: self._process(sim, geometry, unit, weather) 9/20/2019 11:37 AM: 2.xml: 11:54 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/20/2019 11:37 AM: 2.xml: 11:54 AM: 1.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/20/2019 11:37 AM: 2.xml: 11:54 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/20/2019 11:37 AM: 2.xml: 11:54 AM: 1.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/20/2019 11:37 AM: 2.xml: 11:54 AM: 1.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/20/2019 11:37 AM: 1.xml: 11:56 AM: 2.xml: Traceback (most recent call last): 9/20/2019 11:37 AM: 1.xml: 11:56 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/20/2019 11:37 AM: 1.xml: 11:56 AM: 2.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/20/2019 11:37 AM: 1.xml: 11:56 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/20/2019 11:37 AM: 1.xml: 11:56 AM: 2.xml: sim.process(cost_file) 9/20/2019 11:37 AM: 1.xml: 11:56 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/20/2019 11:37 AM: 1.xml: 11:56 AM: 2.xml: self._processSystemSizing(geometry, unit, weather) 9/20/2019 11:37 AM: 1.xml: 11:56 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/20/2019 11:37 AM: 1.xml: 11:56 AM: 2.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/20/2019 11:37 AM: 1.xml: 11:56 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/20/2019 11:37 AM: 1.xml: 11:56 AM: 2.xml: self._process(sim, geometry, unit, weather) 9/20/2019 11:37 AM: 1.xml: 11:56 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/20/2019 11:37 AM: 1.xml: 11:56 AM: 2.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/20/2019 11:37 AM: 1.xml: 11:56 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/20/2019 11:37 AM: 1.xml: 11:56 AM: 2.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/20/2019 11:37 AM: 1.xml: 11:56 AM: 2.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/20/2019 11:38 AM: 2.xml: 11:56 AM: 1.xml: Traceback (most recent call last): 9/20/2019 11:38 AM: 2.xml: 11:56 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/20/2019 11:38 AM: 2.xml: 11:56 AM: 1.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/20/2019 11:38 AM: 2.xml: 11:56 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/20/2019 11:38 AM: 2.xml: 11:56 AM: 1.xml: sim.process(cost_file) 9/20/2019 11:38 AM: 2.xml: 11:56 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/20/2019 11:38 AM: 2.xml: 11:56 AM: 1.xml: self._processSystemSizing(geometry, unit, weather) 9/20/2019 11:38 AM: 2.xml: 11:56 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/20/2019 11:38 AM: 2.xml: 11:56 AM: 1.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/20/2019 11:38 AM: 2.xml: 11:56 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/20/2019 11:38 AM: 2.xml: 11:56 AM: 1.xml: self._process(sim, geometry, unit, weather) 9/20/2019 11:38 AM: 2.xml: 11:56 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/20/2019 11:38 AM: 2.xml: 11:56 AM: 1.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/20/2019 11:38 AM: 2.xml: 11:56 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/20/2019 11:38 AM: 2.xml: 11:56 AM: 1.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/20/2019 11:38 AM: 2.xml: 11:56 AM: 1.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/20/2019 11:38 AM: 1.xml: 11:59 AM: 2.xml: Traceback (most recent call last): 9/20/2019 11:38 AM: 1.xml: 11:59 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/20/2019 11:38 AM: 1.xml: 11:59 AM: 2.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/20/2019 11:38 AM: 1.xml: 11:59 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/20/2019 11:38 AM: 1.xml: 11:59 AM: 2.xml: sim.process(cost_file) 9/20/2019 11:38 AM: 1.xml: 11:59 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/20/2019 11:38 AM: 1.xml: 11:59 AM: 2.xml: self._processSystemSizing(geometry, unit, weather) 9/20/2019 11:38 AM: 1.xml: 11:59 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/20/2019 11:38 AM: 1.xml: 11:59 AM: 2.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/20/2019 11:38 AM: 1.xml: 11:59 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/20/2019 11:38 AM: 1.xml: 11:59 AM: 2.xml: self._process(sim, geometry, unit, weather) 9/20/2019 11:38 AM: 1.xml: 11:59 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/20/2019 11:38 AM: 1.xml: 11:59 AM: 2.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/20/2019 11:38 AM: 1.xml: 11:59 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/20/2019 11:38 AM: 1.xml: 11:59 AM: 2.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/20/2019 11:38 11:59 AM: 2.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/20/2019 11:59 AM: 1.xml: Traceback (most recent call last): 9/20/2019 11:59 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/20/2019 11:59 AM: 1.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/20/2019 11:59 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/20/2019 11:59 AM: 1.xml: sim.process(cost_file) 9/20/2019 11:59 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/20/2019 11:59 AM: 1.xml: self._processSystemSizing(geometry, unit, weather) 9/20/2019 11:59 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/20/2019 11:59 AM: 1.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/20/2019 11:59 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/20/2019 11:59 AM: 1.xml: self._process(sim, geometry, unit, weather) 9/20/2019 11:59 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/20/2019 11:59 AM: 1.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/20/2019 11:59 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/20/2019 11:59 AM: 1.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/20/2019 11:59 AM: 1.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue'
the charts are empty in my beopt output
I asked about this previously and was told to check for an error report. It's here below. Errors related to the clothes dryer don't make sense; Demand response option is False, also standard is selected for appliance schedules. Changing it to DR and enabling the signal on site screen met the similar errors.
9/17/2019 9:10 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/17/2019 9:10 PM: 2.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/17/2019 9:10 PM: 3.xml: sim.process(cost_file) 9/17/2019 9:10 PM: 2.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/17/2019 9:10 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/17/2019 9:10 PM: 3.xml: self._processSystemSizing(geometry, unit, weather) 9/17/2019 9:10 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/17/2019 9:10 PM: 3.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/17/2019 9:10 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/17/2019 9:10 PM: 3.xml: self._process(sim, geometry, unit, weather) 9/17/2019 9:10 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/17/2019 9:10 PM: 3.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/17/2019 9:10 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/17/2019 9:10 PM: 3.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/17/2019 9:10 PM: 3.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/17/2019 9:10 PM: 4.xml: Error: A demand response option was selected (ClothesDryer), but the demand response signal was not enabled on the Site Screen. 9/17/2019 9:10 PM: 1.xml: Traceback (most recent call last): 9/17/2019 9:10 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/17/2019 9:10 PM: 1.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/17/2019 9:10 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/17/2019 9:10 PM: 1.xml: sim.process(cost_file) 9/17/2019 9:10 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/17/2019 9:10 PM: 1.xml: self._processSystemSizing(geometry, unit, weather) 9/17/2019 9:10 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/17/2019 9:10 PM: 1.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/17/2019 9:10 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/17/2019 9:10 PM: 1.xml: self._process(sim, geometry, unit, weather) 9/17/2019 9:10 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/17/2019 9:10 PM: 1.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/17/2019 9:10 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/17/2019 9:10 PM: 1.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/17/2019 9:10 PM: 1.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/17/2019 9:10 PM: 5.xml: Error: A demand response option was selected (ClothesDryer), but the demand response signal was not enabled on the Site Screen. 9/17/2019 9:10 PM: 6.xml: Error: A demand response option was selected (ClothesDryer), but the demand response signal was not enabled on the Site Screen. 9/17/2019 9:51 PM: 2.xml: Traceback (most recent call last): 9/17/2019 9:51 PM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/17/2019 9:51 PM: 2.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/17/2019 9:51 PM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/17/2019 9:51 PM: 3.xml: Traceback (most recent call last): 9/17/2019 9:51 PM: 2.xml: sim.process(cost_file) 9/17/2019 9:51 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/17/2019 9:51 PM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/17/2019 9:51 PM: 3.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/17/2019 9:51 PM: 2.xml: self._processSystemSizing(geometry, unit, weather) 9/17/2019 9:51 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/17/2019 9:51 PM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/17/2019 9:51 PM: 3.xml: sim.process(cost_file) 9/17/2019 9:51 PM: 2.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/17/2019 9:51 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/17/2019 9:51 PM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/17/2019 9:51 PM: 3.xml: self._processSystemSizing(geometry, unit, weather) 9/17/2019 9:51 PM: 2.xml: self._process(sim, geometry, unit, weather) 9/17/2019 9:51 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/17/2019 9:51 PM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/17/2019 9:51 PM: 3.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/17/2019 9:51 PM: 2.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/17/2019 9:51 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/17/2019 9:51 PM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/17/2019 9:51 PM: 3.xml: self._process(sim, geometry, unit, weather) 9/17/2019 9:51 PM: 2.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/17/2019 9:51 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/17/2019 9:51 PM: 2.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/17/2019 9:51 PM: 3.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/17/2019 9:51 PM: 3.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/17/2019 9:51 PM: 3.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/17/2019 9:51 PM: 3.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/17/2019 9:51 PM: 4.xml: Error: A demand response option was selected (ClothesDryer), but the demand response signal was not enabled on the Site Screen. 9/17/2019 9:51 PM: 1.xml: Traceback (most recent call last): 9/17/2019 9:51 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/17/2019 9:51 PM: 1.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/17/2019 9:51 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/17/2019 9:51 PM: 1.xml: sim.process(cost_file) 9/17/2019 9:51 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/17/2019 9:51 PM: 1.xml: self._processSystemSizing(geometry, unit, weather) 9/17/2019 9:51 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/17/2019 9:51 PM: 1.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/17/2019 9:51 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/17/2019 9:51 PM: 1.xml: self._process(sim, geometry, unit, weather) 9/17/2019 9:51 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/17/2019 9:51 PM: 1.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/17/2019 9:51 PM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/17/2019 9:51 PM: 1.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/17/2019 9:51 PM: 1.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/17/2019 9:51 PM: 5.xml: Error: A demand response option was selected (ClothesDryer), but the demand response signal was not enabled on the Site Screen. 9/17/2019 9:51 PM: 6.xml: Error: A demand response option was selected (ClothesDryer), but the demand response signal was not enabled on the Site Screen. 9/20/2019 11:19 AM: 2.xml: Error: A demand response option was selected (ClothesDryer), but the demand response signal was not enabled on the Site Screen. 9/20/2019 11:20 AM: 1.xml: Traceback (most recent call last): 9/20/2019 11:20 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/20/2019 11:20 AM: 1.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/20/2019 11:20 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/20/2019 11:20 AM: 1.xml: sim.process(cost_file) 9/20/2019 11:20 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/20/2019 11:20 AM: 1.xml: self._processSystemSizing(geometry, unit, weather) 9/20/2019 11:20 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/20/2019 11:20 AM: 1.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/20/2019 11:20 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/20/2019 11:20 AM: 1.xml: self._process(sim, geometry, unit, weather) 9/20/2019 11:20 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/20/2019 11:20 AM: 1.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/20/2019 11:20 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/20/2019 11:20 AM: 1.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/20/2019 11:20 AM: 1.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/20/2019 11:30 AM: 2.xml: Error: A demand response option was selected (ClothesDryer), but the demand response signal was not enabled on the Site Screen. 9/20/2019 11:30 AM: 1.xml: Traceback (most recent call last): 9/20/2019 11:30 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/20/2019 11:30 AM: 1.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/20/2019 11:30 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/20/2019 11:30 AM: 1.xml: sim.process(cost_file) 9/20/2019 11:30 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/20/2019 11:30 AM: 1.xml: self._processSystemSizing(geometry, unit, weather) 9/20/2019 11:30 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/20/2019 11:30 AM: 1.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/20/2019 11:30 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/20/2019 11:30 AM: 1.xml: self._process(sim, geometry, unit, weather) 9/20/2019 11:30 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/20/2019 11:30 AM: 1.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/20/2019 11:30 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/20/2019 11:30 AM: 1.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/20/2019 11:30 AM: 1.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/20/2019 11:36 AM: 2.xml: Traceback (most recent call last): 9/20/2019 11:36 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/20/2019 11:36 AM: 2.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/20/2019 11:36 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/20/2019 11:36 AM: 2.xml: sim.process(cost_file) 9/20/2019 11:36 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/20/2019 11:36 AM: 2.xml: self._processSystemSizing(geometry, unit, weather) 9/20/2019 11:36 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/20/2019 11:36 AM: 2.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/20/2019 11:36 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/20/2019 11:36 AM: 2.xml: self._process(sim, geometry, unit, weather) 9/20/2019 11:36 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/20/2019 11:36 AM: 2.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/20/2019 11:36 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/20/2019 11:36 AM: 2.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/20/2019 11:36 AM: 2.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/20/2019 11:36 AM: 1.xml: Traceback (most recent call last): 9/20/2019 11:36 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/20/2019 11:36 AM: 1.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/20/2019 11:36 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/20/2019 11:36 AM: 1.xml: sim.process(cost_file) 9/20/2019 11:36 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/20/2019 11:36 AM: 1.xml: self._processSystemSizing(geometry, unit, weather) 9/20/2019 11:36 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/20/2019 11:36 AM: 1.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/20/2019 11:36 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/20/2019 11:36 AM: 1.xml: self._process(sim, geometry, unit, weather) 9/20/2019 11:36 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/20/2019 11:36 AM: 1.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/20/2019 11:36 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/20/2019 11:36 AM: 1.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/20/2019 11:36 AM: 1.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/20/2019 11:37 AM: 2.xml: Traceback (most recent call last): 9/20/2019 11:37 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/20/2019 11:37 AM: 2.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/20/2019 11:37 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/20/2019 11:37 AM: 2.xml: sim.process(cost_file) 9/20/2019 11:37 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/20/2019 11:37 AM: 2.xml: self._processSystemSizing(geometry, unit, weather) 9/20/2019 11:37 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/20/2019 11:37 AM: 2.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/20/2019 11:37 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/20/2019 11:37 AM: 2.xml: self._process(sim, geometry, unit, weather) 9/20/2019 11:37 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/20/2019 11:37 AM: 2.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/20/2019 11:37 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/20/2019 11:37 AM: 2.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/20/2019 11:37 AM: 2.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/20/2019 11:37 AM: 1.xml: Traceback (most recent call last): 9/20/2019 11:37 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/20/2019 11:37 AM: 1.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/20/2019 11:37 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/20/2019 11:37 AM: 1.xml: sim.process(cost_file) 9/20/2019 11:37 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/20/2019 11:37 AM: 1.xml: self._processSystemSizing(geometry, unit, weather) 9/20/2019 11:37 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/20/2019 11:37 AM: 1.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/20/2019 11:37 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/20/2019 11:37 AM: 1.xml: self._process(sim, geometry, unit, weather) 9/20/2019 11:37 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/20/2019 11:37 AM: 1.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/20/2019 11:37 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/20/2019 11:37 AM: 1.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/20/2019 11:37 AM: 1.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/20/2019 11:38 AM: 2.xml: Traceback (most recent call last): 9/20/2019 11:38 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/20/2019 11:38 AM: 2.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/20/2019 11:38 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/20/2019 11:38 AM: 2.xml: sim.process(cost_file) 9/20/2019 11:38 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/20/2019 11:38 AM: 2.xml: self._processSystemSizing(geometry, unit, weather) 9/20/2019 11:38 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/20/2019 11:38 AM: 2.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/20/2019 11:38 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/20/2019 11:38 AM: 2.xml: self._process(sim, geometry, unit, weather) 9/20/2019 11:38 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/20/2019 11:38 AM: 2.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/20/2019 11:38 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/20/2019 11:38 AM: 2.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/20/2019 11:38 AM: 2.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/20/2019 11:38 AM: 1.xml: Traceback (most recent call last): 9/20/2019 11:38 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/20/2019 11:38 AM: 1.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/20/2019 11:38 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/20/2019 11:38 AM: 1.xml: sim.process(cost_file) 9/20/2019 11:38 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/20/2019 11:38 AM: 1.xml: self._processSystemSizing(geometry, unit, weather) 9/20/2019 11:38 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/20/2019 11:38 AM: 1.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/20/2019 11:38 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/20/2019 11:38 AM: 1.xml: self._process(sim, geometry, unit, weather) 9/20/2019 11:38 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/20/2019 11:38 AM: 1.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/20/2019 11:38 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/20/2019 11:38 AM: 1.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/20/2019 11:38 AM: 1.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/20/2019 11:54 AM: 2.xml: Traceback (most recent call last): 9/20/2019 11:54 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/20/2019 11:54 AM: 2.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/20/2019 11:54 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/20/2019 11:54 AM: 2.xml: sim.process(cost_file) 9/20/2019 11:54 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/20/2019 11:54 AM: 2.xml: self._processSystemSizing(geometry, unit, weather) 9/20/2019 11:54 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/20/2019 11:54 AM: 2.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/20/2019 11:54 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/20/2019 11:54 AM: 2.xml: self._process(sim, geometry, unit, weather) 9/20/2019 11:54 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/20/2019 11:54 AM: 2.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/20/2019 11:54 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/20/2019 11:54 AM: 2.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/20/2019 11:54 AM: 2.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/20/2019 11:54 AM: 1.xml: Traceback (most recent call last): 9/20/2019 11:54 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/20/2019 11:54 AM: 1.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/20/2019 11:54 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/20/2019 11:54 AM: 1.xml: sim.process(cost_file) 9/20/2019 11:54 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/20/2019 11:54 AM: 1.xml: self._processSystemSizing(geometry, unit, weather) 9/20/2019 11:54 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/20/2019 11:54 AM: 1.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/20/2019 11:54 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/20/2019 11:54 AM: 1.xml: self._process(sim, geometry, unit, weather) 9/20/2019 11:54 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/20/2019 11:54 AM: 1.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/20/2019 11:54 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/20/2019 11:54 AM: 1.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/20/2019 11:54 AM: 1.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/20/2019 11:56 AM: 2.xml: Traceback (most recent call last): 9/20/2019 11:56 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/20/2019 11:56 AM: 2.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/20/2019 11:56 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/20/2019 11:56 AM: 2.xml: sim.process(cost_file) 9/20/2019 11:56 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/20/2019 11:56 AM: 2.xml: self._processSystemSizing(geometry, unit, weather) 9/20/2019 11:56 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/20/2019 11:56 AM: 2.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/20/2019 11:56 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/20/2019 11:56 AM: 2.xml: self._process(sim, geometry, unit, weather) 9/20/2019 11:56 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/20/2019 11:56 AM: 2.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/20/2019 11:56 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/20/2019 11:56 AM: 2.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/20/2019 11:56 AM: 2.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/20/2019 11:56 AM: 1.xml: Traceback (most recent call last): 9/20/2019 11:56 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/20/2019 11:56 AM: 1.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/20/2019 11:56 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/20/2019 11:56 AM: 1.xml: sim.process(cost_file) 9/20/2019 11:56 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/20/2019 11:56 AM: 1.xml: self._processSystemSizing(geometry, unit, weather) 9/20/2019 11:56 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/20/2019 11:56 AM: 1.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/20/2019 11:56 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/20/2019 11:56 AM: 1.xml: self._process(sim, geometry, unit, weather) 9/20/2019 11:56 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/20/2019 11:56 AM: 1.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/20/2019 11:56 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/20/2019 11:56 AM: 1.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/20/2019 11:56 AM: 1.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/20/2019 11:59 AM: 2.xml: Traceback (most recent call last): 9/20/2019 11:59 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/20/2019 11:59 AM: 2.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/20/2019 11:59 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/20/2019 11:59 AM: 2.xml: sim.process(cost_file) 9/20/2019 11:59 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/20/2019 11:59 AM: 2.xml: self._processSystemSizing(geometry, unit, weather) 9/20/2019 11:59 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/20/2019 11:59 AM: 2.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/20/2019 11:59 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/20/2019 11:59 AM: 2.xml: self._process(sim, geometry, unit, weather) 9/20/2019 11:59 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/20/2019 11:59 AM: 2.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/20/2019 11:59 AM: 2.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/20/2019 11:59 AM: 2.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/20/2019 11:59 AM: 2.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue' 9/20/2019 11:59 AM: 1.xml: Traceback (most recent call last): 9/20/2019 11:59 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 13803, in <module> 9/20/2019 11:59 AM: 1.xml: y = EnergyPlusInput(xmlfile, cost_file=sys.argv[3]) 9/20/2019 11:59 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\energyplus.py", line 41, in __init__ 9/20/2019 11:59 AM: 1.xml: sim.process(cost_file) 9/20/2019 11:59 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 1397, in process 9/20/2019 11:59 AM: 1.xml: self._processSystemSizing(geometry, unit, weather) 9/20/2019 11:59 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sim.py", line 10097, in _processSystemSizing 9/20/2019 11:59 AM: 1.xml: unit.systemsizing = sizing.SystemSizing(self, geometry, unit, weather) 9/20/2019 11:59 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 33, in __init__ 9/20/2019 11:59 AM: 1.xml: self._process(sim, geometry, unit, weather) 9/20/2019 11:59 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 100, in _process 9/20/2019 11:59 AM: 1.xml: self._processCoolingLoadFloors(sim, mj8, geometry, unit) 9/20/2019 11:59 AM: 1.xml: File "C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\sizing.py", line 997, in _processCoolingLoadFloors 9/20/2019 11:59 AM: 1.xml: mj8.CoolingLoad_Floors += floor.surface_type.Uvalue * floor.area * (space_below.cool_design_temp_mj8 - mj8.cooling_setpoint) 9/20/2019 11:59 AM: 1.xml: AttributeError: 'SurfaceType' object has no attribute 'Uvalue'
