I created a restocking schedule from the Schedule tab (default, summer peak, and winter peak). The daily values are between 0 and 90 (I'm not sure of the units). I defined the schedule properly when I created it.
I then created an open display refrigeration case, but the case will not accept the restocking schedule (i.e., nothing appears in the field when I try to select it).
What's going on? Have I made an error?
Thanks,
Dan
