I want to calculate the load of a large space using RoomAir:TemperaturePattern:NondimensionalHeight in "UserDefinedRoomAirPatterns.idf".
What does the “Thermostat Offset” in “NondimensionalHeight” mean?
I want to calculate the load using "IdealloadAirSystem" and setpoint schedules and temperature in HVACTemplate:Thermostat.
Is the temperature set here (Thermostat temperature) the same as the Thermostatic Offset temperature in RoomAir:TemperaturePattern:NondimensionalHeight?
If the Thermostat Offset in "NondimensionalHeight" is set, does it mean that the average temperature of the zone is fixed?
