Hello,
when using btap_equest_converter to covert an INP file to OSM, I got the following error:
Standard Output:
[10:40:46.886782 WARN] No valid weather file defined in either the osm or osw.
INFO: loading file:Z:/Projects/2018074_TPEE_TP/data/EXPORT/RevitEnergyModel_20190520/Doe2Standard.inp
[10:57:07.220854 ERROR] undefined method `construction=' for #
Z:/Projects/Git/vlle-devs/OpenStudio-CENB/measures/btap_equest_converter/resources/equest.rb:2333:in `block (3 levels) in organize_data'
Z:/Projects/Git/vlle-devs/OpenStudio-CENB/measures/btap_equest_converter/resources/equest.rb:2331:in `each'
Z:/Projects/Git/vlle-devs/OpenStudio-CENB/measures/btap_equest_converter/resources/equest.rb:2331:in `block (2 levels) in organize_data'
Z:/Projects/Git/vlle-devs/OpenStudio-CENB/measures/btap_equest_converter/resources/equest.rb:2329:in `each'
Z:/Projects/Git/vlle-devs/OpenStudio-CENB/measures/btap_equest_converter/resources/equest.rb:2329:in `block in organize_data'
Z:/Projects/Git/vlle-devs/OpenStudio-CENB/measures/btap_equest_converter/resources/equest.rb:2328:in `each'
Z:/Projects/Git/vlle-devs/OpenStudio-CENB/measures/btap_equest_converter/resources/equest.rb:2328:in `organize_data'
Z:/Projects/Git/vlle-devs/OpenStudio-CENB/measures/btap_equest_converter/resources/equest.rb:2178:in `load_inp'
Z:/Projects/Git/vlle-devs/OpenStudio-CENB/measures/btap_equest_converter/measure.rb:420:in `run'
I tried to look inside equest.rb (ex. line 2333) but I could not find any solution for this problem. Indeed, I also tried using converter with some test files downloaded from https://github.com/canmet-energy/btap/tree/master/measures_development/btap_equest_converter, and it worked. But for my building, I don't know why the error undefined method "construction=" for #
Any help?
Thanks a lot
