Keep the Chilled water supply temperature at a stable value
The chiller needs running all year round, but I find the chilled water supply temperature is different in summer and winter even though the chilled water in variable flow rate. I wonder how can I keep the Chilled water supply temperature at a stable value. Thank you very much.
