Hello all
I´m trying to insert 80 liters per day hot water consumption (Portuguese regulation stuff, OpenStudio 1.6.0, E+ 8.2)
I have 1 hour consumption Schedule, and I am trying to change the flow rate on the shower and sink (2x) to 0.000111 x 60s x 60mn, and this would go up to 79.9
Yes, I saw the video on the water heating systems, it works, but actually the value in "Peak Flow Rate" does not "stick" there, and a new one stays at zero.
I tried in another computer and the issue persists: is it only me or this model? I tried altering in Energyplus 8.2, which is easy, but when I import I loose the corrected values, as the systems are lost.
Thanks in advance.
