Hello all,
The measure AEDG Office HVAC CHW keeps failing in PAT for me. I tried applying the measure in OpenStudio to see if it is just the measure, and it might be the case. the measure fails and I get the following message:
image:
image:
image:
I tried deleting the measure from my local library and then re-downloading it for PAT and the openstudio test, but got the same result. Failed to apply the measure, and a failed run in PAT. Sorry in advance if pictures do not post correctly.
