I have data points for power for a piece of equipment in terms of Outdoor Air Temperature Drybulb and Outdoor Air Temperature Wetbulb that is a bit sparse. I'm trying to use the Table:TwoIndependentVariables to modify the schedule of an ElectricEquipment using EMS to include the energy usage in the simulation. I have been able to get the IDF file to simulate, but I have been able to output at all correct results. (Usually the same value for the entire simulation.) The documentation needs some updating in the IO Reference, but otherwise the Table:TwoIndependentVariables is fairly straightforward to use. This makes me think that I'm trying to use the object past its capabilities. For instance, my data points are sparse so the interpolation will often be in the middle of a square with the corners having known x,y input and z output.
Can the Table:TwoIndependentVariables do what I need? If yes, I'll try to make a minimal working example of the behavior. If not, could you please recommend another method? I'll provide more detail about what I'm trying to do in that case.
