Hello to everyone, I´m modeling a bulding with 3 levels and return plenums in each level, for this I´m using a VRF equipment. In the HVAC System tab I just added a VRF system and 12 terminals for each thermal zone (no plenum included). Once I run run the model, in the openstudio report, at the Zone Equipment Detail tab it shows this error:
Zone Equipment Detail section failed and was skipped because: undefined method `maxHeatingCapacity' for #. Detail on error follows.
["C:/Users/ocamp/AppData/Local/Temp/OpenStudioApp.w13356/resources/measures/OpenStudioResults/measure.rb:278:in eval'\nC:/Users/ocamp/AppData/Local/Temp/OpenStudioApp.w13356/resources/measures/OpenStudioResults/resources/Siz.HVACComponent.rb:6:in
maxHeatingCapacity'\nC:/Users/ocamp/AppData/Local/Temp/OpenStudioApp.w13356/resources/measures/OpenStudioResults/resources/os_lib_reporting.rb:824:in public_send'\nC:/Users/ocamp/AppData/Local/Temp/OpenStudioApp.w13356/resources/measures/OpenStudioResults/resources/os_lib_reporting.rb:824:in
block in general_component_summary_logic'\nC:/Users/ocamp/AppData/Local/Temp/OpenStudioApp.w13356/resources/measures/OpenStudioResults/resources/os_lib_reporting.rb:813:in each'\nC:/Users/ocamp/AppData/Local/Temp/OpenStudioApp.w13356/resources/measures/OpenStudioResults/resources/os_lib_reporting.rb:813:in
general_component_summary_logic'\nC:/Users/ocamp/AppData/Local/Temp/OpenStudioApp.w13356/resources/measures/OpenStudioResults/resources/os_lib_reporting.rb:1509:in zone_equipment_component_summary_logic'\nC:/Users/ocamp/AppData/Local/Temp/OpenStudioApp.w13356/resources/measures/OpenStudioResults/resources/os_lib_reporting.rb:1543:in
block (2 levels) in zone_equipment_detail_section'\nC:/Users/ocamp/AppData/Local/Temp/OpenStudioApp.w13356/resources/measures/OpenStudioResults/resources/os_lib_reporting.rb:1541:in each'\nC:/Users/ocamp/AppData/Local/Temp/OpenStudioApp.w13356/resources/measures/OpenStudioResults/resources/os_lib_reporting.rb:1541:in
block in zone_equipment_detail_section'\nC:/Users/ocamp/AppData/Local/Temp/OpenStudioApp.w13356/resources/measures/OpenStudioResults/resources/os_lib_reporting.rb:1533:in each'\nC:/Users/ocamp/AppData/Local/Temp/OpenStudioApp.w13356/resources/measures/OpenStudioResults/resources/os_lib_reporting.rb:1533:in
zone_equipment_detail_section'\n(eval):1:in block in run'\nC:/Users/ocamp/AppData/Local/Temp/OpenStudioApp.w13356/resources/measures/OpenStudioResults/measure.rb:278:in
eval'\nC:/Users/ocamp/AppData/Local/Temp/OpenStudioApp.w13356/resources/measures/OpenStudioResults/measure.rb:278:in block in run'\nC:/Users/ocamp/AppData/Local/Temp/OpenStudioApp.w13356/resources/measures/OpenStudioResults/measure.rb:274:in
each'\nC:/Users/ocamp/AppData/Local/Temp/OpenStudioApp.w13356/resources/measures/OpenStudioResults/measure.rb:274:in run'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.3/lib/openstudio/workflow/util/measure.rb:471:in
apply_measure'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.3/lib/openstudio/workflow/util/measure.rb:74:in block in apply_measures'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.3/lib/openstudio/workflow/util/measure.rb:32:in
each_index'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.3/lib/openstudio/workflow/util/measure.rb:32:in apply_measures'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.3/lib/openstudio/workflow/jobs/run_reporting_measures.rb:85:in
perform'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.3/lib/openstudio/workflow/run.rb:269:in step'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.3/lib/openstudio/workflow/run.rb:216:in
run'\n:/openstudio_cli.rb:937:in execute'\n:/openstudio_cli.rb:726:in
execute'\n:/openstudio_cli.rb:1703:in
'\neval:110:in
eval'\neval:110:in require_embedded_absolute'\neval:95:in
block in require'\neval:89:in each'\neval:89:in
require'\neval:2:in `
