I wrapped one energyplus reference building into FMU and try to simulate the Energyplus-fmu using Pyfmi. My EnergyPlus has 60 seconds as the timestep size.
It looks like it can not go through. Any insightful comments are thankful.
The error i got: File "test_fmi2.py", line 15, in <module> status = model.do_step(current_t = t, step_size= step_size, new_step=True) AttributeError: 'pyfmi.fmi.FMUModelME2' object has no attribute 'do_step
The code snippet i am using is as below:
from pyfmi import load_fmu
model = load_fmu(MyEnergyplus.fmu")
start_time = 0
final_time = 60.0 * 60 * 24 * 3 #seconds
step_size = 60 # seconds
opts = model.simulate_options()
idf_steps_per_hour = 60
ncp = (final_time - start_time)/(3600./idf_steps_per_hour)
opts['ncp'] = ncp
t = 0
