What is the significance of the error,I have used 2ZoneHVACDatacenter idf file. How do i solve this problem ?
ERROR :
** Severe ** CalcIndirectResearchSpecialEvapCooler: calculate secondary air mass flow failed for Indirect Evaporative Cooler Research Special = EAST DATA CENTER IEC
** ~~~ ** Environment=WHOLEYEARDAY, at Simulation time=03/26 18:15 - 18:30
** ~~~ ** Iteration limit [500] exceeded in calculating secondary air mass flow rate
** ~~~ ** Simulation continues
** Severe ** CalcIndirectResearchSpecialEvapCooler: calculate secondary air mass flow failed for Indirect Evaporative Cooler Research Special = WEST DATA CENTER IEC
** ~~~ ** Environment=WHOLEYEARDAY, at Simulation time=03/27 06:03 - 06:05
