In openstudio I have a Coil:Cooling:DX:SingleSpeed which I would like to run with inlet air conditions different from the outdoor air. In the Input-Output Reference I have found that one can specify the "Outdoor Condenser Air Node" which I specified opening the .osm with a text editor. After I run a simulation, the error log tells me that that specific node should be specified in the outdoor air node list. I can find this object in the in.idf generated after the simulation, but I can't find it in the .osm file. Thus, if I modify it in the in.idf, those changes are not affecting the .osm model. My question is if is it possible to include that specific idf object into my .osm file. I have searched for some measure, but I did not find exactly what I am looking for.
