OS:Coil:Cooling:Dx:SingleSpeed model application outside standard scenario
I have used the OS:Coil:Cooling:Dx:SingleSpeed object to model ASHP which uses the extraction air from rooms as a heat sink, instead of using the external air. I have used a slightly different procedure to determine the coefficients needed for the performance curves since the manufacturer data reflected the machine working conditions and they were not useful for the application in the excel sheet "Curve Fit Tool_Cooling_Air" found in E+ folders.
Because I was not sure of the results of this approach, I decided to test the model with a simple box. The idea is to use particular conditions (for outdoor and indoor air, loads configuration, etc) in order to obtain constant values for thermal and electrical power of the machine. Obtaining in the output the temperatures which are the dependant and independent variables of the performance curves, it is possible to recalculate the curves values, using the coefficients and the simulation results.
So, I tried to lure the software into applying the DX coil model with the temperatures I would have in the real operation scheme: I altered the weather file (with elements), in order to have the "room conditions" for %RH and T, so the model would have used those instead of the standard outdoor conditions for the evaporator side. Then I inserted in the air loop, just between the outdoor air mixer and the DX coil, an electrical reheat and an electrical humidifier. In this way, I could replicate the outdoor air conditions I wanted to test.
Given the fact that what I obtained is not in good agreement with what I was expecting, my question is: is someone already have approached a similar problem? I am not sure I can replicate the real machine behavior using the OS:Coil:Cooling:Dx:SingleSpeed model proposed in the software.
edit: inserted image for clarity image description
edit II: I know that the problem might be assessed using EMS or measures. I am really interested in solving the problem, so I am up also for writing my own code part. I tried to understand how to write measure, but still, I am very confused on how to start writing and where should I write them. I have consulted the EMS Application Guide and also The Openstudio Measure Reference, but I still have doubts about the very basics. In my mind, I have been thinking on either a measure or an EMS which should control the air inlet conditions for the OS:Coil:Cooling:Dx:SingleSpeed, in order to override the outside conditions and use the exhaust air ones. The problem is that it is unclear to me where to start doing that.
