Hello,When using the 3-phase method for dynamic simulation, I encountered the following problems. Firstly,If a window on a wall has two different xml files on the top and bottom of the glass, like semi-transparent pv window, how to use these two xml files in the 3-phase method ? Secondly, in 3-phase method how to set the parameters of glow about glazing_glow, sky_glow and ground_glow ? What effect does the set value have? Is there a regular value? Thank you.
