I'm trying to create a model that uses a pump to pump a fluid from a low pressure environment to a high pressure environment. The source and sink are both Boundary_pT and the pump is connected to two static pipes which are then connected to these boundaries. I get the following error:
"Wrong pump curve -- head_nominal must be monotonically decreasing with increasing V_flow_nominal"
How do I fix this?
Thanks!
