Hi, I`ve got some errors in Energy Plus EMS as below - could anyone help?
* Severe * Invalid Output:Variable or Output:Meter Name =SURFACE PROPERTY SOLAR ABSORPTANCE * ~~~ * Entered in EnergyManagementSystem:Sensor=SOLAR_TEMPERATURE_1 * ~~~ * Output:Variable Name not found * Severe * Invalid Output:Variable or Output:Meter Name =SURFACE PROPERTY SOLAR ABSORPTANCE * ~~~ * Entered in EnergyManagementSystem:Sensor=SOLAR_TEMPERATURE_2 * ~~~ * Output:Variable Name not found * Severe * Invalid Actuated Component Unique Name =BLOCK1:ZONE1:WALL_1_WINDOW_1_SEGMENT_MID * ~~~ * Entered in EnergyManagementSystem:Actuator=OPENFACTOR1 * ~~~ * Component Unique key name not found * ~~~ * Review edd file for valid component names. * Severe * Invalid Actuated Component Control Type =CONSTRUCTION STATE * ~~~ * Entered in EnergyManagementSystem:Actuator=OPENFACTOR1 * ~~~ * Control Type not found * ~~~ * Review edd file for valid component control types. * Fatal * Errors found in processing Energy Management System input. Preceding condition causes termination.
