I have a built up PSZ air handler (I'm not using a Unitary system; I have a standard built up air handler with a chilled water coil, a max humidity setpoint manager on the cooling coil air outlet node, a humidistat in the zone, and the controller water coil is configured to meet both sensible and latent load) configured to provide max humidity control. In a proposed case model where the cooling coil is hardsized everything works fine. When I autosize for a baseline case, the cooling coil can't keep up with the dehumidification load. I tried to change the type of load field in Sizing:System to Latent or Total (instead of Sensible) but that didn't have any effect. Is there any way to get the autosizing routine to size the system to meet both the sensible and latent load?
