Hello World!
I am still newby in EnergyPlus and stucked in PlantLoop object usage. I am trying to simulate a Solar Cooling System through an absorption chiller. I have 4 loops.
1- Glycol Water Loop, 2- Hot Water Loop, 3-Chilled Water Loop, 4-Cooling Tower Loop
As I understand from User Manual of EnergyPlus about PlantLoops "Plant Application Guide", after I identify the branches, connectors, splitters and all the other equipment I should define the loops with PlantLoop object.
I got confused, because in the Plant Application Guide, only chillers, cooling towers and boilers are identified in PlantLoop object.
All the branches and equipment are identified in EnergyPlus and now I need to use PlantLoop object. Can I use PlantLoop object for all these 4 loops?? Or should I use it for equipment which is identified as PlantObject in energyplus?
Thanks in advance
