Hi,
Running a simulation with a small building with a high density load (91M2 and 300 Kw equipment's load) the system deliver this error.
After check the construction and test with different thermal load, the system run without problems with 250 Kw equipment's load, this situation leads me to think that there must be some configuration that limits the models to certain load densities, can some body help me to understand or identify whit setting can be modified to let high equipment's load in the model? High power densities are very usual in datacenters.
Thanks
Hugo Jojoa
