Hello everyone,
I am currently modeling various FCU 4 pipe systems and I am strugling with properly sizing the water cooling coils. In particular, I would like to ask what may be causing my "Cooling Coils --> Design Coil Load [W]" output in "Equipment Summary" section to always result in 0 if I hardsize the cooling coil design conditions based on my known project conditions, i.e., if i leave all inputs as "autosize" the design coil load is not 0, however if I input data the result is 0 W.
AUTOSIZED
HARDSIZED
INPUTS
Thank you all in advance.
