In the PAT documentation it explains:
To download all datapoints, including the timeseries csv output for each simulation, run the scripts/download_datapoints.rb script using the OpenStudio CLI. The script requires that the Timeseries CSV Export reporting measure be included in your PAT project. Supply all required arguments to the script, including project directory, server DNS, and analysis ID. A usage example is given as follows: $ /c/openstudio-2.8.1/bin/openstudio.exe scripts/download_datapoints.rb -p project_singlefamilydetached -s http://ec2-107-23-165-146.compute-1.amazonaws.com -a 706c3b4a-9685-4924-bb13-c6bec77aa397 Additionally, the script has an optional argument to unzip each datapoint zip file on the fly.
I have tried running the openstudio_cli.rb script and I keep getting this error:
/System/Library/Frameworks/Ruby.framework/Versions/2.3/usr/lib/ruby/2.3.0/rubygems/core_ext/kernel_require.rb:55:in require': cannot load such file -- openstudio (LoadError)
    from /System/Library/Frameworks/Ruby.framework/Versions/2.3/usr/lib/ruby/2.3.0/rubygems/core_ext/kernel_require.rb:55:inrequire'
    from openstudio_cli.rb:32:in `<main>'
Does anyone know why or can someone explain how to properly access the Timeseries output?
Thank you in advance,
Ravi
